Best way to sync calendar and contacts between Outlook 365 and Outlook on iPhone
Neil McCubbin
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    win 11 iOS
Outlook version:     classic outlook 2407
Email type or host:    IMAP
I am running Outlook 365 with mail service by WHC.ca using IMAP. Outlook for iOS on iPhone
All latest versions
My email address is @McCubbin.ca Perhaps this personal domain is an issue We have two addresses we would want to sync
I see three possible ways to have smooth two-way sync (like I had when using an MS Exchange server)
1) iCloud Microsoft instructions make it look very easy, but it does not work for for me. My Contacts from PC appeared on iPhone, but changes do not sync, either way.
2) Using CalDAVsynchroniser I have tried, but cannot get it to work. Neither can the techies at WHC. I get reports like the attached every few hours
3) via OUtlook.com I have not tried that
What is best approach?
Am I creating problems by trying both (1) and (2) ? If so, how to start again?
I have over 20 hours into this, and am fed up, so any help would be much appreciated.
I prefer gsyncit - its not free but works and unlike the iCloud sync addin, it leaves the items in the default folders so Outlook today or the To-Do bar works.
outlook.com is a good free method, but meeting responses may go out from the outlook.com account.
Are you using an app password when you set up the sync utility? That is required to connect with icloud.
Thanks for your rapid reply
I had never heard of an app password. Now I have some idea since I just googled it
I am not using one
Microsoft suggests that I cannot sync contacts and calendars from my mccubbin.ca IMAP account. Refer to URL below
Can you refer me to a URL showing how to do it?
You can't sync calendar and contacts stored on the web using an IMAP account, its email only. If you have some when you log into webmail, they will not sync with imap. You can sync them using gsyncit.
BTW - if you are using outlook.com address, they are turning off basic auth and eliminating app passwords in mid-September. So if you needed one, it would stop working then.
Ideally, when you log into the account on a new device, should apply the settings that were used on the account before, by the way, I advise you to buy Microsoft 365, useful for the office thing
C Best way to keep clinic quotes organized in Outlook? Using Outlook 1
Horsepower What is best calendar practice for iMac Using Outlook 3
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest Using Outlook 0
X Best utility for repairing PST files? Using Outlook 3
S Best method to use Outlook Standalone with iPhone Using Outlook 13
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
T IMAP mail sync is extremely slow Using Outlook 6
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
