Where is the best place to store values for combobox entries
  • Thread starter Thread starter escamoteur
E
escamoteur
I want to add to my custom inspector form a combobox that contains values that the user can define. E.g. Project status.
If Outlook were a relational database I would store this values just in it's own table and populate the combobox from there.
How is the best way to achieve this in Outlook??
Best
Tom
Databases, spreadsheets, text files, even Outlook items all can be used to
store such values. You'd use code behind the form to load them when the form
displays and to update the storage source with any new values the user might
have defined. The best approach for specific sceneario depends in part on
the intended scope of the row values. Are they specific to a single item? A
single user? All users?
Sue Mosher
"escamoteur" <mail@burkharts.net> wrote in message
news:6C13F02E-ED52-4C31-89BA-CCF8549BFC0C@microsoft.com...
> Hi,
> Best
> Tom
Is this a fixed list or a list that can change?
What version of Outlook?
> Hi,
> Best
> Tom
Sorry for not beeing more specific.
It's Outlook 2007 and it will be a single user plugin that should be configurable by the user. I want to have everything stored in
the .pst file if possible.
Think of the list like the Categories of outlook items, only that this categories only belong to my item type. The user should be
able to add and delete categories that he needs.
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:%23fNrQ3TFKHA.5780@TK2MSFTNGP03.phx.gbl...
> "escamoteur" <mail@burkharts.net> wrote in message news:6C13F02E-ED52-4C31-89BA-CCF8549BFC0C@microsoft.com...
> > Hi,
>> Best
>> Tom
OK, if this is only for Outlook 2007 or later then I'd recommend using a
StorageItem for that. A StorageItem is what's know in MAPI circles as a
hidden item, in the Associated Contents table for a folder. You can use a
StorageItem in any folder and it's invisible to the user. It can only be
accessed using code, so users can't mess around with your hidden storage.
Using that you can store the list in the body of the hidden item as a
newline separated list and then just split the body on newlines (carriage
return + line feed) when you want to recover or modify the list.
That way the list will travel with the PST file and should do what you want.
news:%23Vrcf0aFKHA.3696@TK2MSFTNGP02.phx.gbl...
> configurable by the user. I want to have everything stored in the .pst
> file if possible.
> categories only belong to my item type. The user should be able to add and
> Best
> Tom
Thanks a lot, that was what I was looking for.
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:O0uxCTdFKHA.4732@TK2MSFTNGP04.phx.gbl...
> > file if possible.
>> Best
>> Tom
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 10
G Outlook Contact Item.Restrict where FullName is NULL Outlook VBA and Custom Forms 3
J OUTLOOK 2016 FILE STORAGE WHERE COMMAND Using Outlook 12
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
S Views ans Where Settings AreSavd Using Outlook 4
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Horsepower Where did Evenote come from? Using Outlook 6
tswatek Issue with where Outlook saves new contacts Using Outlook 3
snissen Where is "Edit Message" in Outlook 2016? Using Outlook 2
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Where did my categorized emails go? Using Outlook 1
H Where to post code in Outlook Outlook VBA and Custom Forms 1
P Where are the cached emails stored? Using Outlook.com accounts in Outlook 2
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
J Linking Contacts to a Message Where the Contact isn't an Addressee Using Outlook 1
L How do i choose where i file my sent messages? Using Outlook 1
C Outlook 2007 Contact Card opens in margin of screen where I can't see it Using Outlook 3
P Where the heck is the data? Using Outlook 10
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
B Can't locate in Outlook custom form where is message from Using Outlook 4
B help: where are outlook2000 email accounts stored Using Outlook 14
Rupert Dragwater Where to find folders in Outlook 2010 Using Outlook 4
S Where is the BCM SDK?? BCM (Business Contact Manager) 1
B Where are my emails that I already? Using Outlook 1
G Where are Saved Reports physically stored? BCM (Business Contact Manager) 0
O Where is Launcher, the custom action for Exchange server? Exchange Server Administration 1
J Where is Final Release BCM 2010, Microsoft? Why is Dev Team silent BCM (Business Contact Manager) 2
B Where is RTM version of BCM 2010? BCM (Business Contact Manager) 2
N Where have all the helpful people gone in this forum? BCM (Business Contact Manager) 3
S Custom Fields - Deleting And Where Are They Saved Outlook VBA and Custom Forms 8
M WHERE without using CASE Outlook VBA and Custom Forms 3
S Where to publish my custom form ? Outlook VBA and Custom Forms 4
P Where are User-defined fields stored in BCM 2010 database? BCM (Business Contact Manager) 2
E Where is Business Contact Manager?? BCM (Business Contact Manager) 2
T Where is "administrative groups" Exchange Server Administration 9
D Where does Outlook store signatures? Outlook VBA and Custom Forms 9
