Outlook and Access integration using VBA
  • Thread starter Thread starter Rhys Davies
Rhys Davies
Hi there, in our access database i have code that allows a user to create an
outlook appointment, which can be seen below:
Dim objOutlook As Object
Dim objItem As Object
Set objOutlook = CreateObject("Outlook.Application")
Set objItem = objOutlook.CreateItem(olAppointmentItem)
With objItem
> Subject = Title & " " & ": Appointment"
objItem.Display
Set objOutlook = Nothing
however, what would be really useful is if it could go one step further and
open existing calendar items rather thana new item. we have a section on the
access database where users enter activity i.e. work done with a client on a
particular date - it would be really nice if when the user selects a date on
this activity screen that they could also maybe hit a command button that
would open up their outlook calendar on the same date as the date selected
within access itself so they can quicky copy and paste some of the
information that they have previosuly entered in their calendar into their
activity. or even that hitting the button opens up an access form that holds
information from the relevant fields from their outlook calendar - i have
seen this done and have done it myself but the opposite way i.e. you write it
into outlook. unfortunately this now doesnt work for us because we do our
activity retrospectively.
any help would be greatly appreciated
In Outlook 2007 the Explorer supports the CurrentView property, whcih
returns a CalendarView object if the current folder is a calendar. And the
CalendarView supports the GotoDate function.
Best regards
Michael Bauer
Am Thu, 25 Mar 2010 06:36:01 -0700 schrieb Rhys Davies:
an
> With objItem
> .Subject = Title & " " & ": Appointment"
> End With
> objItem.Display
and
the
a
on
holds
it
J Outlook, Word, Access crash unless run in Admin mode - time dependent it seems Using Outlook 10
T Render Outlook emails in MS access as they appear in Outlook Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
R How can I access my emails from corrupt offline files of MS Outlook ? Using Outlook 1
F Outlook 2016 bulk email from access Outlook VBA and Custom Forms 3
T Cannot access outlook.com accounts in Outlook 2016 Using Outlook 1
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Change Outlook's Programmatic Access Options Using Outlook 0
C Merging Word and Access into Outlook Using Outlook 4
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
B No permission to access Outlook.pst file Using Outlook 1
U Cannot access fields at bottom of Outlook 2013 Contact Rec. Using Outlook 1
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
L Outlook Data Files command not working in the quick access bar Using Outlook 1
Hudas Hyperlink Saved Outlook Email to MS Access Table Using Outlook 4
Hudas Import Outlook Emails(Inbox) to MS Access as Attachment Using Outlook 1
M How do I access a contact list subfolder in Outlook 2013? Using Outlook 5
K how to Access Outlook Contact Properties Using Outlook 1
M Outlook client macro to web access Using Outlook 1
M Access replicated Outlook (email folders, calendar, contacts, notes) via web Using Outlook 1
R Limiting Outlook Access to Inside Network Only Exchange Server Administration 1
J Outlook and owa access Using Outlook 1
O Can't create new email or access email acounts Outlook 2003 Using Outlook 1
C MAPI to access a 64 bit Outlook from a 32 bit application; or access via ODBC Using Outlook 0
C Synchronize outlook with access Using Outlook 1
J Unable to access public folders in Outlook 2007 on Exchange 2010. OWA PF works fine Using Outlook 7
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
R Access Program Only Looping Part Way Through Outlook Inbox Outlook VBA and Custom Forms 2
H Exporting Outlook Forms to Access or Excel Outlook VBA and Custom Forms 2
P Access - Outlook Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
K Outlook admin vs individual access (VBA pulling info) Outlook VBA and Custom Forms 1
S Sending Email from Access 2007 through Outlook 2007 using template Outlook VBA and Custom Forms 13
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
G Linking Outlook to Access for Contacts in Access Outlook VBA and Custom Forms 3
R Programming Web Outlook Access Outlook VBA and Custom Forms 3
D "Outlook has blocked access to this form template file. Outlook VBA and Custom Forms 3
S Programming Outlook from MS Access (Inbox) Outlook VBA and Custom Forms 1
