Redemption not working on OL2007
  • Thread starter Thread starter Peter Hibbs
P
Peter Hibbs
I am writing a database in Access 2003 which uses the Redemption.dll
code to send emails without the warning message. This works fine on
Outlook 2003 but the person who will be using this database has
Outlook 2007 installed and, when they send an email, nothing happens.
The email is not sent and it does not show up in the Drafts folder (as
it does in 2003).
Is there a work around or a later version of the dll which can fix the
problem or could it be an error in the code.
TIA
Peter Hibbs.
What version of Redemption are you using?
What is the relevant snippet of your code? Does Outlook run whe nyour code
is executed?
Dmitry Streblechenko (MVP)
"Peter Hibbs" <peter.hibbs@btinternet.com.NO_SPAM> wrote in message
news:6g8815dg1r25momr6154bdipbhvok6eeak@4ax.com...
> it does in 2003).
> TIA
> Peter Hibbs.
Dmitry,
Hope you are still watching this thread, my users were a bit slow in
getting back to me and I have also got them doing a bit more testing.
The Version Number is - 4.7.0.1026
What they have is Mozilla Thunderbird as their main email program (and
is the default email program) as well as Outlook. It would seem that
the Redemption code only works if Outlook is the default program (I
got them to swap them over to check that).
They have now made Outlook as the default program for outgoing emails
(I don't know how as I don't know too much about Outlook) and they are
using the Thunderbird program for incoming emails.
With this set up the automatic emails work OK so they are happy now.
Thanks for your help and the excellent redemption code and if you have
any further comments on this arrangement I will pass them on to my
users.
Peter Hibbs.
On Wed, 20 May 2009 17:14:58 -0700, "Dmitry Streblechenko"
> is executed?
W Redemption::RDOMail.PrintOut() / DoAction(maPrint) not working Outlook VBA and Custom Forms 1
D Auto Remove [EXTERNAL] from Subject + ConversationTopic (WITHOUT Redemption plug-in) Outlook VBA and Custom Forms 5
N Redemption VBA basics...something's missing Using Outlook 0
D Redemption? Need rapid pull of Outlook Contacts, email + notes for VBA Using Outlook 1
J 64-bit version of Redemption? Outlook VBA and Custom Forms 2
E Redemption access AppointmentItem Label from outlook Outlook VBA and Custom Forms 6
B Use Redemption to get sender's email address Outlook VBA and Custom Forms 3
M EMail1Address and EMail1AddressType strangeness using Redemption Outlook VBA and Custom Forms 2
A Creating Redemption.MAPIUtils failed with Windows 7 x64 Outlook VBA and Custom Forms 5
D href tags does not result in the full url with Redemption Outlook VBA and Custom Forms 4
E Redemption Foldes.Add doesn't work Outlook VBA and Custom Forms 3
N Redemption.RDOSession logon() stops emails sending-they stay in Ou Outlook VBA and Custom Forms 3
E Should I switch to redemption Outlook VBA and Custom Forms 11
C Redemption - Rules for outlook Outlook VBA and Custom Forms 1
G Error in Outlook Object Model with redemption and google apps prem Outlook VBA and Custom Forms 3
P Redemption Send EMail Outlook VBA and Custom Forms 10
T Configure mailbox OutofOffice with Redemption Outlook Outlook VBA and Custom Forms 1
D redemption dll not registering in windows vista Outlook VBA and Custom Forms 3
Y Redemption MessageItem SaveAs problem Outlook VBA and Custom Forms 8
Q GAL.ResolveName issue with REDEMPTION Outlook VBA and Custom Forms 5
Q REDEMPTION HANGING during LOGON Outlook VBA and Custom Forms 2
P Redemption Send EMail fails Outlook VBA and Custom Forms 4
S delete appointmentitem permanently using redemption Outlook VBA and Custom Forms 2
D redemption - foldercreate event + delegate user Outlook VBA and Custom Forms 8
C Assign To and CC list while using Redemption.dll library Outlook VBA and Custom Forms 10
U Re: Read fields with Redemption Outlook VBA and Custom Forms 1
V redemption MAPIUtils Outlook VBA and Custom Forms 3
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
