Load audio file into Media Player control
  • Thread starter Thread starter news.microsoft.com
N
news.microsoft.com
Hello, I've created an Outlook add-in with a Form region that contains
Windows Media player control, all works fine when running it, but my
question is how do I have the media control load the audio file that is
attached to the email when I open the email.
These message have their own message class with the form is associated with,
and they always contain one wave file.
Frank
Get the Attachments collection of the item in question and iterate each
Attachment member object until you find the wave file. You can check the
Attachment.FileName property to see if the wave file extension is there.
Once you've found the attachment use the Attachment.SaveAsFile method to
save it to the file system, perhaps to a temp file, then call the player to
work with that file. After you are finished you may want to delete the
temporary file.
"news.microsoft.com" <frank@new.scom> wrote in message
news:eZzCx59oJHA.5412@TK2MSFTNGP04.phx.gbl...
> with, and they always contain one wave file.
> Thanks
> Frank
Thank you that did the trick... I was hoping that there would be some
"built-in" function that would allow me to access the file directly... but
the suggestion worked just as good.
Frank
news:uPzuIx%23oJHA.1288@TK2MSFTNGP02.phx.gbl...
> to work with that file. After you are finished you may want to delete the
> temporary file.
>> Thanks
> > Frank
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
J VB6 Add-in fails to load in Outlook 16 - message useless Outlook VBA and Custom Forms 4
Diane Poremsky Always Load an Outlook Addin Using Outlook 1
William getting custom form to load category colors Outlook VBA and Custom Forms 4
J BCM 2013 in Outlook 2013 will not load BCM (Business Contact Manager) 5
H Macro to load an Outlook Template Using Outlook 2
M Load a template when you reply Using Outlook 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
S Outlook 2007 Add-in strange load behavior Outlook VBA and Custom Forms 10
G "Cannot load GUI library into memory" Outlook VBA and Custom Forms 3
D Why does BCM not always load when I restart Outlook? BCM (Business Contact Manager) 1
G Using VBA to load the CC line on an Outlook email Outlook VBA and Custom Forms 2
S BCM does not load in Windows 7 BCM (Business Contact Manager) 1
P Can you load an OlkComboBox and show a previously selected value? Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
P What is it, and why won't it load? BCM (Business Contact Manager) 10
M VBA Form how to load in Outlook 2003 Outlook VBA and Custom Forms 4
S Business Data Import and Export Load Error Cannot Map BCM (Business Contact Manager) 1
D Outlook AddIn can't load outside Visual Studio Outlook VBA and Custom Forms 1
D Application.ActiveInspector() is Null on Ribbon Load Outlook VBA and Custom Forms 1
Q Load a recipient based on a value in a combo box Outlook VBA and Custom Forms 7
S Business contact manager will not load? databinding? BCM (Business Contact Manager) 2
J add-in won't load Outlook VBA and Custom Forms 12
O How will a new Exchange profile handle existing .ost file stored elsewhere? Using Outlook 4
R File not found when sending email with attached pdf file Using Outlook 2
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
M Why oft-file opens as outbox not as draft Outlook VBA and Custom Forms 4
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
T Cannot open .pst file Using Outlook 2
D DB/Object/Record vs File/List/Range Terminology Outlook VBA and Custom Forms 0
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
