Load a recipient based on a value in a combo box
Q
Q2x1ZWxlc3M
I have a custom Outlook 2007 form that I need help with writing code to
perform the following.
I have two Drop Down boxes: Box 1. person - responsibility Box 2. location
- person
When a certain person is selected in the 1st. Box I want the person's name
to automatically load as a recipient of the email. I would also like to be
able to add an additional name as a recipients to the same email when Box 2.
Has a location and person selected. I use the following code to fill in a
recipient based on a click event but I am not sure how to do an event based
on the value in a drop down box
Sub CommandButton2_Click()
Recipients.Add "Doe, John"
Recipients.ResolveAll
Recipients.Add "Smith, Bill"
Thanks In advance
Sue Mosher [MVP]
The event to use depends on whether the control is bound to an Outlook
property. See http://www.outlookcode.com/article.aspx?ID=38
Sue Mosher
"Clueless" <Clueless> wrote in message
news:BFA946AF-B1F5-4504-AE87-5782C76780D0@microsoft.com...
> location
> - person
> 2.
> based
> End Sub
> Thanks In advance
Q
Q2x1ZWxlc3M
Sue,
The control is bound, I used the Item PropertyChange (ByVal name)
The following code would put John Doe has the recipent but it kept doing it
multiple times until outlook locked up. I want the recipient to be add just
once or removed and changed based on the My.Control.Value. in my Combo Box.
Sub Item_PropertyChange(ByVal Name)
Set MyPage = Item.GetInspector.ModifiedFormPages("Requisition Form")
Set MyControl = MyPage.Controls("ComboBox24")
If Right(MyControl.Value,1) = "e" Then
Set Recipient = Recipients.Add ("Doe, John")
Recipient.Type = 1
What am I missing?
> > Sue Mosher
> > location
> > - person
> > 2.
> > based
> > End Sub
> > Thanks In advance
Sue Mosher [MVP]
Please look again at the sample code on the page I suggested. It shows how
to run code only on a change to the property you're interested in, not all
properties.
Also, if the control is bound, your code should work with the property
value, not the control value. And I suspect it's bound to a custom property,
not a standard property, which means you need to use the
CustomPropertyChange event.
Sue Mosher
news:D57432AB-13C9-4BD3-B70F-BEEEF1C0C81E@microsoft.com...
> Sue,
> it
> just
> Box.
> Recipient.Type = 1
> End If
> End Sub
> What am I missing?
> Thanks
> > > location
> > > - person
> > > name
> > > be
> > > Box
> > > 2.
> > > a
> > > based
> > > End Sub
Q
Q2x1ZWxlc3M
Sue,
You were correct I was not understanding the code correctly but I do have it
working from your instructions. However, I am trying to use the change
property values event but want it to also to occur based on a check box
click even. for example.
If the check box is true when the change property values occurs nothing
happens but once the checkbox is clicked the change properties value then is
initiated. I can't seem to nest the events. What I have below only occurs
after the box is clicked and then I go back and select the drop down box
again. Thanks in advance
ub Item_CustomPropertyChange(ByVal Name)
Set MyControl = MyPage.Controls("CheckBox14")
If MyControl.Value = True then
Select Case Name
Case "Vendor"
strMyProp1 = Item.UserProperties("Vendor")
Select Case Right(strMyProp1,1)
Case "n"
Recipient.Type = 1
Case "g"
Set Recipient = Recipients.Add ("Wilson, greg")
Recipient.Type = 1
Case "r"
Set Recipient = Recipients.Add ("Ross, Mike")
Recipient.Type = 1
> properties.
> > Sue Mosher
> > Sue,
> > it
> > just
> > Box.
> > Recipient.Type = 1
> > End If
> > End Sub
> > What am I missing?
> > Thanks
> >> > location
> >> > - person
> >> > name
> >> > be
> >> > Box
> >> > 2.
> >> > a
> >> > based
> >> > End Sub
Sue Mosher [MVP]
Is the check box bound or unbound? If bound, to what property? Is Vendor the
name of the property bound to the combo box with the list of names in it?
Sue Mosher
news:510A1947-6CD8-49A7-8762-3760A0C708FB@microsoft.com...
> Sue,
> it
> is
> Select Case Name
> Case "Vendor"
> Case "n"
> Recipient.Type = 1
> End Select
> Case "g"
> Recipient.Type = 1
> End Select
> Case "r"
> Recipient.Type = 1
> End Select
> End Select
> End If
> End Sub
> > how
> > all
> > properties.
> > property,
> > > Sue,
> > > doing
> > > it
> > > just
> > > Box.
> > > Recipient.Type = 1
> > > End If
> >> > End Sub
> >> > What am I missing?
> >> > Thanks
> > >> >to
> > >> > location
> > >> > - person
> > >> > person's
> > >> > name
> > >> > to
> > >> > be
> > >> > when
> > >> > Box
> > >> > 2.
> > >> > in
> > >> > a
> > >> > event
> > >> > based
> > >> > End Sub
Q
Q2x1ZWxlc3M
Sue,
I was able to figure it out based on your examples in your link.
My new issues is that I have created a custom form with check boxes that
display names in the recipient field when selected. When I run the form all
the code works as I need, but if some one receives the form and forwards to
someone else the code will not longer activate. I did not have this issue
with Outlook 2003, but when I went to 2007 and recreated my form I could nt
get it to work like Outlook 2003.
Outlook 2003 tool bar allowed anyone to access the form in the
organizational library then edit the form before sending. The receiver of the
outlook 2003 for coudl then go to tool bars, forms, run this form then send
it to the next person for review. How can I get this to work in outlook 2007,
it does not seem to give the same option as 2003. Please help or gving me
some reading to understadn what I need to do.
Thanks for all your help
> > Sue Mosher
> > Sue,
> > it
> > is
> > Select Case Name
> > Case "Vendor"
> > Case "n"
> > Recipient.Type = 1
> > End Select
> > Case "g"
> > Recipient.Type = 1
> > End Select
> > Case "r"
> > Recipient.Type = 1
> > End Select
> > End Select
> > End If
> > End Sub
> >> how
> >> all
> >> properties.
> >> property,
> >> > Sue,
> >> > doing
> >> > it
> >> > just
> >> > Box.
> >> > Recipient.Type = 1
> >> > End If
> >> >> > End Sub
> >> >> > What am I missing?
> >> >> > Thanks
> >> >> >to
> >> >> > location
> >> >> > - person
> >> >> > person's
> >> >> > name
> >> >> > to
> >> >> > be
> >> >> > when
> >> >> > Box
> >> >> > 2.
> >> >> > in
> >> >> > a
> >> >> > event
> >> >> > based
> >> >> > End Sub
Sue Mosher [MVP]
It sounds like your form is not properly published to the Organizational
Forms library with the "send form definition with item" box unchecked. Only
properly published forms can run code. See
http://www.outlookcode.com/article.aspx?id=61?
Also, the Forward action on the form design's Actions page needs to point to
the published form.
Sue Mosher
news:4B07516E-0031-4404-891C-AD5F80B10427@microsoft.com...
> all
> to
> nt
> the
> send
> 2007,
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
J VB6 Add-in fails to load in Outlook 16 - message useless Outlook VBA and Custom Forms 4
Diane Poremsky Always Load an Outlook Addin Using Outlook 1
William getting custom form to load category colors Outlook VBA and Custom Forms 4
J BCM 2013 in Outlook 2013 will not load BCM (Business Contact Manager) 5
H Macro to load an Outlook Template Using Outlook 2
M Load a template when you reply Using Outlook 1
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
S Outlook 2007 Add-in strange load behavior Outlook VBA and Custom Forms 10
G "Cannot load GUI library into memory" Outlook VBA and Custom Forms 3
D Why does BCM not always load when I restart Outlook? BCM (Business Contact Manager) 1
G Using VBA to load the CC line on an Outlook email Outlook VBA and Custom Forms 2
S BCM does not load in Windows 7 BCM (Business Contact Manager) 1
P Can you load an OlkComboBox and show a previously selected value? Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
P What is it, and why won't it load? BCM (Business Contact Manager) 10
M VBA Form how to load in Outlook 2003 Outlook VBA and Custom Forms 4
S Business Data Import and Export Load Error Cannot Map BCM (Business Contact Manager) 1
D Outlook AddIn can't load outside Visual Studio Outlook VBA and Custom Forms 1
D Application.ActiveInspector() is Null on Ribbon Load Outlook VBA and Custom Forms 1
S Business contact manager will not load? databinding? BCM (Business Contact Manager) 2
J add-in won't load Outlook VBA and Custom Forms 12
N Load audio file into Media Player control Outlook VBA and Custom Forms 2
F Graphics in email / Mac recipient garbled Using Outlook 0
T Outlook 2010 recipient no longer shows in 'Send To' Using Outlook 0
C Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 4
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
J Signatures that contain recipient's email address Outlook VBA and Custom Forms 7
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
M recipient cache? Using Outlook 2
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
H How to show recipient email address? Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
J Searh For Recipient Email address Outlook VBA and Custom Forms 1
A Extracting only one recipient from Msgitem.To Outlook VBA and Custom Forms 7
Diane Poremsky Display the Recipient Email Address in the Sent Items Folder Using Outlook 0
E Meeting reminders are set for the recipient Exchange Server Administration 9
