VBA: Send-From Code for Template Shortcut?
discgolfdc
Outlook 2013 64 bit
Hi, all! I'd have to imagine that this should be a fairly easy question for those who know anything more than I do (which isn't saying a whole lot).
I am trying to get some shortcut buttons in a custom Outlook ribbon tab/group that I've created, and I understand how to do that as well as assign macros to those new buttons I'll be putting there. I am using the following macro to call up an OFT template to prepare it for sending:
Sub OpenCustomTemplate()
  Set newItem = Application.CreateItemFromTemplate("C:\Users\Me\AppData\Roaming\Microsoft\Templates\Initial Instructor Paperwork Send.oft")
  newItem.Display
My problem is this: I have two exchange accounts on our server - one in my name (myname@institution.com), and the other in the name of a specific department I coordinate (departmentname@institution.com). The departmental account was recently tied to my profile, so the "default" account is the one under my name. Is there anything I can add to that code so as to force the newItem to default to being sent from departmentname rather than from myname? When I call up the template using the above code, it always defaults to sending from myname. I know I can always hit the "From" button in the template once it's called up, but if I can automate it, it would be better for me.
Any ideas?
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
K VBA to prompt and send a CC Outlook VBA and Custom Forms 6
D Outlook VBA to open Excel attachment and send recipient's email address to a workbook cell? Using Outlook 4
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
V "Accept + Send the Response now", VBA script? Using Outlook 1
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
S Send All emails in Outbox and Quit using VBA Outlook VBA and Custom Forms 3
D Using VBA to send Word document as body of message works in 2007, but not in 2003 Outlook VBA and Custom Forms 9
