UserForm Code For Contact Links
Any update today from the Smart Woman???? ;) In the past you have given me the full code to copy and paste to the VBA....and this time, I do need the full code based on what I showed you and you know what to put and where!!!! And I would be very excited to get this done!!! ;)
I was given the following from someone that sorts the combobox for Categories....so if you see this, what should I do to sort the combobox for the Contacts that show up:
He changed the Private Sub UserForm_Initialize() and added a Function below it
'The loads the Outlook userform and populates the combobox of contact folders.
Dim objFolder As Outlook.MAPIFolder
Dim Category
' Declare variable to use
Dim arrCategories() ' the array
Dim i As Long
Dim lngCount As Long
Dim arrSorted() As Variant ' Results of sorting held here
Dim First As Integer
Dim Last As Integer
Set objOutlook = CreateObject("Outlook.Application")
' Initialize i to zero
i = 0 ' Used later when populating array
' Determine what size the array will be
lngCount = Application.Session.Categories.Count
' Resize array with determined size
ReDim arrCategories(lngCount)
ReDim arrSorted(lngCount)
' Start populating array with categories
For Each Category In Application.Session.Categories
arrCategories(i) = Category
i = i + 1
' Call the sorting function and store the sorted array in variable
arrSorted = f_SortArray(arrCategories)
' Using the newly sorted array as the source to the drop-down, traverse it adding
' elements as items to drop-down list
First = LBound(arrSorted)
Last = UBound(arrSorted)
For i = First To Last - 1
Me.ddlCategories.addItem arrSorted(i)
Next i
' The drop-down list should now be sorted
' Take this model in your ddlContacts_Change event
Function f_SortArray(ArrayToSort() As Variant) As Variant
Dim Last As Integer
Dim i As Integer
Dim j As Integer
Dim Temp As String
First = LBound(ArrayToSort)
Last = UBound(ArrayToSort)
For j = i + 1 To Last
If ArrayToSort(i) > ArrayToSort(j) Then
Temp = ArrayToSort(j)
ArrayToSort(j) = ArrayToSort(i)
ArrayToSort(i) = Temp
Next j
Next i
f_SortArray = ArrayToSort
End Function
I sent another email. And would love to hear back from the Smart Woman!!
I'm not that smart. :)
This is part of what needs changed (plus some category stuff later in the code):
you need to count contacts
lngCount = MyContacts.items.Count
(lngCount = MyItem.Count might work too)
arrCategories is just the variable for the array, no need ot change it, except to avoid confusion.
this needs changed,
to
For Each MyItem In MyContacts
As to lngCount = MyContacts.items.Count or lngCount = MyItem.Count , do I replace lngCount = Application.Session.Categories.Count? And then do I just replace For Each Category In Application.Session.Categories with For Each MyItem In MyContacts arrCategories(i) = Category ? And does that affect the sorting of the Categories or just update for both Categories and Contacts to be sorted?
And can you just make all the changes you suggest and anything else as you said needs to adjusted re Categories, so I can just copy and past it and see if it works or tell you the errors etc.??? Thanks so much to he Smart Woman!!!;)
yes, replace the lngCout line with one of the ones i suggested and see if it works.
The function will work with contacts and categories and each one has it's own macro. I don't know if it will affect the category sorting, it shouldn't though. I don't have multiple contacts folders and didn't test it.
I tried both ways and error is 424 "Object required"
If you look real quick at the full code per what you gave me to add, what added dim doi put in please??
That's why I'm not sure what object is missing - the code looks good. I'm obviously missing something though. Try adding
dim myitem as object
don't know if its the board software, but
needs to be on it's own line, not one line with For Each MyItem In MyContacts
Thank you. But as I repeat, i don't understand it all. Please give me the specific code lines and where exactly where to put them as I don't understand the concepts.
Any full update so I have the code which already sorts the Categories and you update the full code to sort the Contacts from all folders together....any chance today or tomorrow?
Got it....and just in case you figure it out, please let me know
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
A Outlook Userform Size Outlook VBA and Custom Forms 2
N Activity Tracking with Userform Outlook VBA and Custom Forms 4
D Next Available Meeting with Userform Variables Outlook VBA and Custom Forms 1
A Populate Excel from Outlook Userform Outlook VBA and Custom Forms 3
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
A Open CHM file from VBA Userform Outlook VBA and Custom Forms 4
L Outlook 2007 - Userform Using Outlook 2
A Focus on the userform Outlook VBA and Custom Forms 15
F Outlook 2010 - outlook userform and combo boxes Using Outlook 9
L Userform Field Month and Date. Using Outlook 19
Witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
X VBA: Confused with variables between ThisOutlookSession and UserForm Using Outlook 1
M Progrescreas Bar in Outlook UserForm Using Outlook 1
C UserForm and ordering variables Outlook VBA and Custom Forms 3
J userform combobox Outlook VBA and Custom Forms 1
R combobox list in userform Outlook VBA and Custom Forms 1
B Userform Outlook VBA and Custom Forms 5
W Using Excel UserForm from Open Workbook in Outlook VBA Outlook VBA and Custom Forms 5
P userform in VBAProject.otm not working Outlook VBA and Custom Forms 1
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
