Outlook ruler issue
Praveen1988
when i click on new message ruler defaults at that.. (1)..i have to use indent each time to set it to 0.. please help
Switch ot the Format Text tab. Right click on the style you're using (probably Normal) and choose Modify. Select the New documents based on the template radio button. Click Format button and choose paragraphs. Left indent should be 0. Click Ok, verify it's applying to new documents and click Ok.
Diane, could you please tell me how to ask a question? You have a wealth of information here but it is a little overbearing for a new user
Also, if I want to check from the existing archive of questions, can i ask "how to put right and left indents for all outgoing e-mails and how to make this the default?
thank you
please consider outlook 2010
This link should load the new post in Outlook page - https://forums.slipstick.com/forums/using-outlook.46/create-thread (it's in the light blue nav bar) - then just ask.
As for the left & right margins if you change the margins in a new message then close without sending, it should stick. However, it's not recommended. Margins are measured in from the sides, not measured in from the left. A 2" margin is going to be 2" in from the left and right. If a recipient uses a narrow window, the text will be narrow because the margins take up 4 inches. See Setting Margins when Composing Email for screenshots.
If you want a message limited to 600 wide (like many ads use) you need to use a table. If you use a wide screen, adjust the width of the compose window so it's are at comfortable width.
P Outlook 2010 Font on Reply Email is Very Small Ruler Will Not Extend Using Outlook 2
J How do I view the ruler in an Outlook message and/or insert tabs? Using Outlook 7
E What is the next workaround for macro in New Outlook 1.2025.1111.100 Outlook VBA and Custom Forms 1
E Need to digitally sign macro but VBA\Outlook crash Outlook VBA and Custom Forms 1
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 3
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 22
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
