VBA environment disabled
brrrknee
I'd written a tool/macro for my outlook 2010 inbox attachments that has worked fine several years; recent updates via MS Update -I apply all critical per MS, and now the VBA project file is 'file not found'.
However the VbaProject.OTM file is there in ...roaming/Microsoft/outlook folder. alt-F11 and the editor shows no project open, nor are any of the menu commands enabled (import/ new, etc.) that might allow me to set the connection to the file again. The only menus not disabled are the help menu and the view to show various editor windows.
I have already tried repairing the Office 2010 but that didn't resolve the issue. I also removed the VBA option via the "add/remove features" for the suite, then repeated to re-install the VBA office add-in. I also changed the outlook VBA add-in registry key's LoadBehavior data item value from 9 (load on demand) to the default of 3 (load at start up) and this also did not change the situation.
as I open Outlook, the splash screen displays, loading the add-ins, then when the macro dialog asks the "thisOutlookSession" macro enable/disable, I elect to enable and immediately get the "file not found," and alt-F11 to open the editor gives me an empty, disabled environment. As noted above the file had always and still does exist at %appdata%\Microsoft\Outlook.
what might have happened, and how do I get the VBA environment working again? any registry or file changes or configurations, please help me get this corrected. Thank you!
It sounds like the vba project file is corrupt. Unfortunately, there is no way to repair it - you need to delete or rename it and start with a fresh one.
Hornblower409 Mailsorter - Find a folder quickly and file the email. With recent history (Free VBA) Using Outlook 1
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
