Macro quetsions
Not a magician - the code just needed to be rearranged to make outlook happy.
oops. Sorry about that - i add message boxes so i know if code is firing. There is a line for msgbox "running" - delete it.
The itemadd macro only watches the inbox and the rules are triggering before the itemadd macro. You have a couple of options - add an exception to the rule that if it has attachment, don't move or use a run a script rule. The scripts need to do all of the actions - so it would need to remove the attachment and move the message - it's not a big deal for a couple of rules, but can get unwieldy if you have a lot of rules.
If you aren't using a lot of folders, you could watch another one or two, but like rules, it gets unwieldy if you need to watch more than a couple of folders.
Well, for me, you are a magician! :)
Thanks for the "run" messagebox, I could eliminate it as you instructed.
Unfortunatelly, I have 67 subfolders, which I am actively using.
Is there any option to set a rule which fires all before the other rules? I mean, the rules has a "stop processing other rules" checkbox, so I assume, its processed in order, arent they? So would it be a stupid idea to add a rule to nr1 position which executes your script?
Also, for some reason, in this new code, the "eliminate my email from to/cc when sending an email" stop working.
To be more precise:
- when I push reply all button example on a sent email, it adds my own email to TO or CC, so thats this code was remove it before email sending, based on my display name: "!" (I know it is stupid display name, but nevermind. )
Any idea why it stopped working?
Many thanks,
Moore
You could try a rule to check the messages - put it at the top of the list then hand the messages off. There is one potential problem - if you get a lot of these messages coming in fast, some could be skipped.
Try this macro - create a rule that points to this macro - it *should* call the itemadd macro and because it's handling the work off to a new macro, seems to handle a larger volume of mail better. The item add macro will still be around to grab any that get dropped in the inbox with the attachment still on it. (I'll test it next to make sure it's working like this.)
Public Sub RemoveATT(Item As Outlook.MailItem)
objNewMailItems_ItemAdd item
FWIW, things like this are one reason we recommend using instant search to find things instead of subfolders to file everything.
The good news: it works.
The bad news: Script rules are client side so the rule won't work with Exchange accounts unless the rules that move are client side - otherwise the message gets moved when it hits the mailbox and the script rule won't work on it.
