"Advanced find: column for full folder path?
Handvprice
In Advanced Find windows, I use the "In Folder" column to show the folder in which emials are located, but have more than one folder with the same name, so it doesn't help me pin it down. I know I can individually open an email and use ctrl+shift+F for another Advanced Find window that will show the containing folder, but that's really clumsy. Is there a form or add-in that will add a column to show the Full Folder Path for all the found files? (I'm thinking analogously to the cfg form code I found online that adds a senders true email address to the email list window). I've found online queries asking for this, but no answers yet. I'm using Outlook 2003, but would be willing to upgrade for this functionality. TY.
No, no form. There is a VBA macro that will get the path and take you to the folder - Get the Message Folder - VBOffice - it could be tweaked to add the folder path to a custom field (or one of the user fields although its not very useful in a search).
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
O Advanced search - can I use booleans Using Outlook 3
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
J search doesn't find anything Using Outlook 1
M Issues with templates - unable to find in old web app Using Outlook 3
Witzker How to find all emails from and to a contact in OL 2019 Using Outlook 6
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
