Is anyone else having problem conneccting to gmail?
Well, I thought I would give this another go today. I do have a question, what is meant by "app password"?
It's a special password that is intended to only be used once, in place of your real password. You can revoke app passwords without changing your real password.
With gmail, apple, and Microsoft you need to have 2-step authentication enabled. Yahoo doesn't require 2-step but does require app passwords.
This is google's explanation -
Hello:
First post here, specifically to respond to this thread.
I have been using Outlook 2019 with POP Gmail configured for over a year without issue. Beginning 7/18/22 my Gmail account will not connect to pop.gmail.com through Outlook, triggering send/receive error 0x800CCC0F: The connection to the server was interrupted. If I remove the account and attempt to recreate it, Outlook reports 'The connection to the incoming (POP) or (IMAP) server was dropped.'
Google retired their 'less secure devices' option back on May 30th, and POP/IMAP connections now require OAuth 2.0 (OAuth2). My Google account has been using 2-Factor Authentication since long before then, and my pop.gmail.com account configured within Outlook has used an app password for over a year. Unfortunately, neither Outlook 2016 nor Outlook 2019 support this security protocol. From what I have read, neither does Outlook 2021.
I even generated new app passwords to help troubleshoot, but the connection continues to drop with Outlook before it ever actually authenticates my account. Meanwhile, Mozilla Thunderbird works fine as it has OAuth2 as an option in the account setup, but is not a preferred replacement.
I will test it- but it should work with the app password. I have a client on Outlook 2007 that uses a macro from processing incoming mail so I hope they don't kill off pop. :(
Did you verify that pop was still enabled in gmail settings?
Welcome to the forum.
Yes, it will try to be broken, but It can definitely be configured to work. See my previous two posts in this thread.
I expect that you have something slightly mis-configured, like maybe the email servers or other switches on those Outlook-2021 screens. IIRC, there is also stuff to do at gmail.com. Let us know and we can try to help you.
@stuartjames
Yes you are correct. So for anyone wanting to add a GMail account to Outlook 2010 (and possibly to Outlook 2019 and another other Outlook version), you will need to add and use an 'App Password' and not your own.
The Outlook login box appeared every time Outlook 2022 checked the Gmail servers late last night. This was always the case with my ISP when they were having email issues in my area in the past. There has been no change to my settings or system, so I suspect Gmail is experiencing some problems with email this morning.
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 4
P anyone use 4n6' Eudora Conversion program or other programs? Using Outlook 1
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 2
J Can Anyone Help?? Outlook VBA and Custom Forms 1
V Anyone Using CodeTwo Sync for iCloud ? Using Outlook 28
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
M Anyone with this Microsoft Outlook issue can help? Using Outlook 1
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
R Anyone have a sample macro for Outlook 2007 (setting the zoom)? Outlook VBA and Custom Forms 1
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
R Calendar says it is connected to someone else Exchange Server Administration 2
M Outlook Today. How to rename IMAP inbox accounts to something else than inbox? Using Outlook 4
S Improving synchronization of Outlook with ... everything else Using Outlook 1
R BCM works, but everything else stopped working BCM (Business Contact Manager) 1
N Having Shared Calendar shift to Current day Using Outlook 0
dbjdbj Is it only me having a fun time with Outlook.com "beta" ? Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
V Problem not having Contacts folder after importing emails from Yahoo. Using Outlook 0
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
J outlook having sort by date or from unable to display sender name. Using Outlook 2
M Having Calander send E-mails Using Outlook 3
B Having Recent Issues with Hotmail Connector? Using Outlook.com accounts in Outlook 17
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
T Get rid of having to type verification characters to send mail BCM (Business Contact Manager) 2
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
A Contact Manager Unable to Initialize...after having tested Office BCM (Business Contact Manager) 1
