MailTips and older Outlook versions
rseiler
OS Version(s)
  1. Windows
Outlook 365 32 bit
Microsoft states that:
The following messaging clients support MailTips:
  • Outlook on the web (formerly known as Outlook Web App)
  • Microsoft Outlook 2010 or later for Microsoft Windows
But does it support all of them? We have "MailTipsAllTipsEnabled" and "MailTipsExternalRecipientsTipsEnabled" enabled in Exchange Online. Newer Outlook clients (e.g. Current Channel) show external emails like this:
But Outlook 2016 merely shows:
You'll notice no "This sender is from outside your organization" MailTip in the latter.
It's not as if it doesn't show any (there is one shown above, and I've seen several others), but not the "outside your organization" one for some reason. You do see it when you click Reply, at least, but I'm talking about before that.
K Outlook 2010 Mailtips - Can they be printed with the email message Using Outlook 1
D Unable to view older emails in desktop app Using Outlook 0
A Sending contact vcards sends older version instead of updated version Using Outlook 4
J Outlook Mailbox cleanup; any way to change limit to find items older 999 days? Exchange Server Administration 2
J Delete emails older than Using Outlook 1
J Macro to move mail from Inbox if older than 4 days Using Outlook 4
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 1
S Volunteer request: opening invented MSG files in Outlook for Windows Using Outlook 0
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 3
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 6
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
B Sync Google Calendar with Outlook Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
