Distribution list does not sync from Outlook to hotmail
if you use the connector, the list should sync up, not down but Hotmail doesn't use DL's, it uses categories instead.
From http://www.slipstick.com/emo/2009/up090528.htm#4
What Hotmail/Live calls "Categories", Outlook knows as Distribution lists. The connector will sync the "category" into Outlook as a distribution list name but it does not sync the members, leaving you with an empty distribution list. Importing DLs has always been buggy and members rarely made it through the import so this comes as no surprise.
Distribution lists created in Outlook will correctly sync to the Live account, adding the DL members to your online contacts if the contact does not exist, and creating the "Category" containing those addresses.
Solution: Create distribution lists in Outlook and let the connector sync them to the server.
T Create a group from a large To distribution list Using Outlook 3
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
D Macro to scan email distribution list when replying Using Outlook 2
J Maintain Distribution List Using Outlook 3
S Finding Distribution List Name Outlook VBA and Custom Forms 3
K Rule for Distribution List Using Outlook 0
M add contacts to shared contacts distribution list Using Outlook 1
E Add sender to distribution list? Using Outlook 3
B Restore deleted contact distribution list Using Outlook 1
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
W Combine Mail Merge to Distribution List with Auto Attachments - Outlook 2007 Using Outlook 1
Jennifer Murphy Distribution list fails after conversion to Unicode PST Using Outlook 2
C Can't import distribution list - help, please Using Outlook 1
M Distribution List with hundreds of emails Using Outlook 1
L Individual E-mails from Distribution List Using Outlook 5
M Import distribution list into MS Exchange Sharepoint Exchange Server Administration 3
T Distribution List - Export/Import Using Outlook 4
K Creating a New Distribution List from an Existing one Using Outlook 0
C How do I hide distribution list from global contacts for certain users? Exchange Server Administration 1
A Lock the distribution list Using Outlook 1
L Sending from a distribution list email Using Outlook 6
J Automatically CC to another user when sending from Distribution List Using Outlook 2
K Autocomplete list not saving distribution list Using Outlook 3
G Posting of Email Messages Using a Distribution List BCM (Business Contact Manager) 1
F Obtain Members of a Distribution List Outlook 2003 c# Outlook VBA and Custom Forms 1
L How do I set up or transfer a distribution list into Global contac BCM (Business Contact Manager) 1
T Outlook 2003 - Making a distribution list from a contact folder Outlook VBA and Custom Forms 1
S Outlook Distribution List contents Outlook VBA and Custom Forms 1
S New Outlook Distribution List Location Outlook VBA and Custom Forms 2
Y auto add contact in a distribution list Outlook VBA and Custom Forms 1
B add to existing distribution list Outlook VBA and Custom Forms 3
S To get members of the distribution list and their managers Outlook VBA and Custom Forms 4
S Maintain Outlook Distribution List from Access Outlook VBA and Custom Forms 2
A How to obtain the Distribution List of a Sender Outlook VBA and Custom Forms 4
M updating and saving contacts in Distribution List Outlook VBA and Custom Forms 2
P Check for the distribution list existence Outlook VBA and Custom Forms 1
D Import Into Existing Distribution List Using Outlook 3
D Distribution List won't stick in BCM BCM (Business Contact Manager) 2
J Expand Distribution List on Send Outlook VBA and Custom Forms 1
S Distribution list failure - "an unexpected error has occurred" Using Outlook 7
K Distribution List BCM (Business Contact Manager) 1
A import email addresses into a distribution list Using Outlook 14
V Re: How can I restore a deleted distribution list to my contacts? Using Outlook 5
E Distribution lists Using Outlook 1
