Recovery of VBA code
  • Thread starter Thread starter F.H. van Zelm
F
F.H. van Zelm
Somehow I lost my VBA code from Outlook (2003). Perhaps by adding a digital
signature ...?
I have no idea what happened.
I restored a backup of an earlier Outlook.pst but that didn't help. No
modules inside.
Can anyone tell me if it is possible to recover VBA code from a backup?
What file, how to restore?
Mvg, Frans
www.fhvzelm.com
The file you need to restore is VbaProject.otm; see
http://www.slipstick.com/config/backup.asp for Outlook file locations.
Sue Mosher
"F.H. van Zelm" <fhvzelm@hotmail.com> wrote in message
news:OGrUeaSCKHA.4168@TK2MSFTNGP05.phx.gbl...
> Hi,
> digital
> signature ...?
> modules inside.
> > Mvg, Frans
> www.fhvzelm.com
Hi Sue,
Thanks for advice.
It became rather stressful because the restored VbaProject.otm was not
accepted, so to say.
Then, first I copied Outlook.pst and Archive.pst and restored all of
D&S\<me>\App Data\...\Outlook
and D&S\<me>\Local Settings\...\Outlook. That worked, I'm só glad. Copied
back the recent
versions of the pst-files.
I still don't know what went wrong: the digital signature or cleaning the
registry to drastically.
So I also have my InsertDate-code back. It used the Redemption add-in to
avoid the warning:
Sub InvoegenDatum()
'Macro voegt huidige datum in op cursorpositie in body van geopend item
'Gebruikt: -
'Gebruikt door: - [Datum]
'Nog doen: -
' ActiveInspector.CurrentItem.Body = ActiveInspector.CurrentItem.Body &
vbCr & Date
'Simpele Outlook
VBA-oplossing
Dim myInspector As Object 'Objectvar voor Redemption
COM
Set myInspector = CreateObject("Redemption.SafeInspector")
'Objectvar initialiseren
myInspector.Item = Application.ActiveInspector
myInspector.SelText = Date 'Datum invoegen op
cursorpositie
Set myInspector = Nothing 'Objectvar legen
Frans van Zelm
www.fhvzelm.com
"Sue Mosher [MVP]" <suemvp@turtleflock.com> schreef in bericht
news:ebcJDQTCKHA.3724@TK2MSFTNGP05.phx.gbl...
> > Sue Mosher
> > Hi,
> > digital
> > signature ...?
> > modules inside.
>> > > Mvg, Frans
> > www.fhvzelm.com
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
A pst recovery Outlook VBA and Custom Forms 1
S Exchange Recovery storage Group Exchange Server Administration 8
