pst recovery
  • Thread starter Thread starter angie
angie
i have outlook 2000 and my file is corrupt because with the emails downloaded
today i have exceeded the 2gb limit.
i have tried the scanpst tool recommended by miscrosoft and i get the
message that the scan has stopped due to an error.
basically i am interested in recovering today's mail because for everything
else i have kept a backup file and i will try to split it in another pc.
is there a way to achieve that? it really important because i have lost
customer's orders!
Your PST file is oversized. Microsoft Outlook 2002 and earlier
versions limit the size of Personal Folders (PST) file to 2GB.
Whenever the PST file reaches or exceeds that limit, you will not be
able to open or load it any more, or you cannot add any new data to
it. This is called oversized PST file problem. More detailed
information can be found at http://www.datanumen.com/aor/problems/2gb-pst.htm
You can use Advanced Outlook Repair to solve the problem, by either
converting it into Outlook 2003 format ( http://www.datanumen.com/aor/problems/convert-2gb-pst.htm
), or splitting it into smaller pieces ( http://www.datanumen.com/aor/problems/split-2gb-pst.htm
http://www.datanumen.com/aor/ contains the detailed information about
Advanced Outlook Repair.
And you can also download a free demo version at http://www.datanumen.com/aor/aor.exe
W.
KuldeepTech How Do I Extract All Emails from a PST File? Using Outlook 1
K I built an open-source, offline OST to PST converter for Windows Using Outlook 9
S PST Reader App Using Outlook 0
S Thank you Diane, Plus pst files question Using Outlook 8
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
B MMF to PST converter Using Outlook 1
S Indexing PST Files Using Outlook 0
S Organizing a .Pst Outlook VBA and Custom Forms 0
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
T Cannot open .pst file Using Outlook 2
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
B How to get PST folder datetime? Outlook VBA and Custom Forms 1
P Recommendation for PST repair program Using Outlook 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J Recover server side rules from OST/PST without access to the server Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
L Article on merging pst file Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
