MMF to PST converter
birddog
OS Version(s)
  1. Windows
Older version
Operating system::    windows 10
Outlook version:     outlook 2013
Email type or host:    imap
I am looking for a way to convert or even view my old MMF files.
That is an audio file? Did you google for a converter?
Please note: this forum is for Outlook and Exchange questions.
This thread is locked as off topic.
KuldeepTech How to Remove Multiple Duplicate Outlook PST Files from My Computer? Using Outlook 3
KuldeepTech How Do I Extract All Emails from a PST File? Using Outlook 1
K I built an open-source, offline OST to PST converter for Windows Using Outlook 11
S PST Reader App Using Outlook 0
S Thank you Diane, Plus pst files question Using Outlook 8
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
S Indexing PST Files Using Outlook 0
S Organizing a .Pst Outlook VBA and Custom Forms 0
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
T Cannot open .pst file Using Outlook 2
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
B How to get PST folder datetime? Outlook VBA and Custom Forms 1
P Recommendation for PST repair program Using Outlook 1
P Outlook 365 Bad experience with KernelAPPS PST Repair program Using Outlook 0
HarvMan Importing PST into IMAP account Using Outlook 12
K Moved pst to new computer, now Gmail not coming into Outlook Using Outlook 7
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
S Import PST to Office 365 Using Outlook 1
J Recover server side rules from OST/PST without access to the server Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
L Article on merging pst file Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
