Outlook Code Problem On Email Moves - Error -2147221233
E
ejek6337
Please review the following code that moves emails between different outlook
box folders and subsequently creates an excel spreadsheet. This code has
always worked, but for some reason it started not working on a few people's
computers. It still works on mine however. They have the same references as
me loaded, namely the VBA, Outlook 11, Office 11, and OLE Automation
references. Here is the code:
' Create session so that security prompt is not displayed in outlook
Set olapp = Application
Set Session = olapp.Session
Set AL = olapp.Session.AddressLists("Global Address List")
Set fld =
olapp.GetNamespace("Mapi").GetFolderFromID("000000000F7EA95D623B0B4191BB263A85023FAC010079A7F373FA835448AE050AECC8235EE1000000E0C1070000")
Set fldSB =
olapp.GetNamespace("Mapi").GetFolderFromID("000000001A447390AA6611CD9BC800AA002FC45A0300B72F7F36FCD61A408C03CA765846D34D0000006EADB40000")
Set fldMoveTemp =
olapp.GetNamespace("Mapi").GetFolderFromID("000000000F7EA95D623B0B4191BB263A85023FAC01007953D6860919C04DB07FDB35A24059AA0000059D53060000")
Set fldMoveFinal =
olapp.GetNamespace("Mapi").GetFolderFromID("000000000F7EA95D623B0B4191BB263A85023FAC01007953D6860919C04DB07FDB35A24059AA0000059D53070000")
If Not fld Is Nothing Then
'a) count the mail items in the folder
intTotalItems = fld.Items.Count
ErrorCount = 0
'3) set the location of the storage file and
' create the Excel worksheet
Dim objWkb As Object 'Excel.Workbook
Dim objWks As Object 'Excel.Worksheet
Dim objExcel As Object 'Excel.Application
Dim i As Integer, j As Integer
'Set objExcel = New Excel.Application
Set objExcel = CreateObject("Excel.Application")
Set objWkb = objExcel.Workbooks.Add
Set objWks = objExcel.ActiveSheet
objWks.Cells(1, 1).Value = "Subject"
objWks.Cells(1, 2).Value = "Received"
objWks.Cells(1, 3).Value = "Sender Name"
objWks.Cells(1, 4).Value = "EMAIL"
objWks.Cells(1, 5).Value = "Body"
objWks.Cells(1, 6).Value = "Notes"
'4) Loop through all emails in the Rome CSBASES Outlook folder and move
them into the Archive Temp Folder
SubRoutine = "CSBASES"
i = fld.Items.Count
Do While (i - ErrorCount) > 0
For Each itm In fld.Items
DoEvents
If itm.Class = olMail Then
itm.Move (fldMoveTemp) ' Problem occurring here in
some cases with error -2147221233 Automation Error
Next_CSBASES:
Next itm
i = fld.Items.Count
Loop
Dmitry Streblechenko
The error is MAPI_E_NOT_FOUND
You are modifying the collection in the "for each" loop.
Use
for i = Items.Coiunt to 1 Step -1
loop instead
Dmitry Streblechenko (MVP)
"ejek6337" <ejek6337@yahoo.com(donotspam)> wrote in message
news:57771D77-D794-406A-9A8C-A8369C2B1693@microsoft.com...
> outlook
> people's
> as
> Set fld =
> Set fldSB =
> Set fldMoveTemp =
> Set fldMoveFinal =
> ErrorCount = 0
> i = fld.Items.Count
> DoEvents
> End If
> Next_CSBASES:
> Next itm
> i = fld.Items.Count
> Loop
E
ejek6337
I gave it a try on mine and it worked. I just need to try it on the other
personnels' computers and will let you know. Thanks.
Ed
> Use
> loop instead
> > outlook
> > people's
> > as
> > Set fld =
> > Set fldSB =
> > Set fldMoveTemp =
> > Set fldMoveFinal =
> > ErrorCount = 0
> > i = fld.Items.Count
> > DoEvents
> > End If
> > Next_CSBASES:
> > Next itm
> > i = fld.Items.Count
> > Loop
P How to get a QR code for automatic signin with Outlook for iOS Using Outlook 5
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
H Where to post code in Outlook Outlook VBA and Custom Forms 1
G Custom Form code not working - Outlook 2010 Outlook VBA and Custom Forms 2
Kelli VBA code for Outlook Using Outlook 1
Wotme code to run outlook add-in Using Outlook 1
S Outlook code to validate textbox value Using Outlook 1
L Outlook 2007 Code for Note Fields of Appointment Using Outlook 102
R Private Sub Application_ItemSend() -Cannot make this code work in Outlook 2013 Using Outlook 0
C Error Code -3253 Outlook for MAC Using Outlook 0
D Outlook Add-In That Calculates Time Based on Area Code Using Outlook 8
J VBA code can't be completely executed in outlook 2013 Using Outlook 0
P VBA Code being completely ignored by Outlook Using Outlook 7
A Outlook VB Code Using Outlook 1
B How do I create and send mail in Outlook 2003 from code? Using Outlook 5
J Create or Import a Outlook Rule through C# code. Outlook VBA and Custom Forms 2
C compile error on previously functioning code outlook 2003 windows Outlook VBA and Custom Forms 1
J Executing Ribbon Command from Code Outlook 2010 Outlook VBA and Custom Forms 3
N why does vb not recognise outlook code? Outlook VBA and Custom Forms 1
D Code to clear certain fields in Outlook Form Outlook VBA and Custom Forms 7
H want to launch outlook with attachemnet for new mail with c# code Outlook VBA and Custom Forms 3
T forcing a rule when opening outlook via code Outlook VBA and Custom Forms 1
A Accessing .pst folder in outlook using VBA Code Outlook VBA and Custom Forms 4
T Outlook setting through code(in >tools >options) Outlook VBA and Custom Forms 1
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
