Outlook not processing all incoming emails
  • Thread starter Thread starter John
John
I am using function NewMailEx as per below code to process attachments from
incoming messages. Problem is Outlook is skipping processing some of the
mail items probably when there are a number of them coming at the same time.
What is the problem and how can I fix it? Is there a more robust way to do
this? I have avoided .net add-in due to installation issues.
Regards
Private Sub Application_NewMailEx(ByVal EntryIDCollection As String)
Dim arr() As String
Dim i As Integer
Dim ns As Outlook.NameSpace
Dim itm As MailItem
Dim m As Outlook.MailItem
Set ns = Application.Session
arr = Split(EntryIDCollection, ",")
For i = 0 To UBound(arr)
Set itm = ns.GetItemFromID(arr(i))
If itm.Class = olMail Then
Set m = itm
For Each Atmt In m.Attachments
' Do some processing here
Next Atmt
Set ns = Nothing
Set itm = Nothing
Set m = Nothing
It shouldn't skip anything. Why do you think it does so?
Best regards
Michael Bauer
Am Fri, 25 Sep 2009 02:47:44 +0100 schrieb John:
> Hi
from
time.
> Thanks
> Regards
> Dim arr() As String
> Dim i As Integer
> Dim itm As MailItem
> Set m = itm
> Next Atmt
> End If
> Next
> Set ns = Nothing
> Set itm = Nothing
> Set m = Nothing
> End Sub
Heavy load?
Regards
"Michael Bauer " <mb@mvps.org> wrote in message
news:z00ryc1ya6gf.h3qxehd5614n$.dlg@40tude.net...
> > Best regards
> Michael Bauer
> > Hi
> from
> time.
> > do
>> Thanks
>> Regards
> > Dim arr() As String
> > Dim i As Integer
> > Dim itm As MailItem
> > Set m = itm
> > Next Atmt
> > End If
> > Next
>> Set ns = Nothing
> > Set itm = Nothing
> > Set m = Nothing
> > End Sub
I don't understand your answer. Does it really skip messages, or just
attachments? If the first, process all the items within the folder, and flag
those that are processed yet (user property); if the latter, it's due to the
code you haven't provided.
Best regards
Michael Bauer
Am Sat, 26 Sep 2009 20:12:24 +0100 schrieb John:
> Heavy load?
> Regards
>> > > Best regards
> > Michael Bauer
> >> Hi
> > from
> > time.
> >> do
>>> Thanks
>>> Regards
> >> Dim arr() As String
> >> Dim i As Integer
> >> Dim itm As MailItem
> >> Set m = itm
> >> Next Atmt
> >> End If
> >> Next
>>> Set ns = Nothing
> >> Set itm = Nothing
> >> Set m = Nothing
> >> End Sub
M Outlook 2016 Desktop - Automatic Rule Processing Using Outlook 3
K Outlook 2013 stuck "processing" when opening. Using Outlook 3
G Keeping Outlook Classic (desktop) PST in Google Drive folder? Using Outlook 0
T How to fix disconnected Outlook account Using Outlook 6
N Outlook Calendar Not Showing All Events Using Outlook 2
F Outlook Data File Column Empty Using Outlook 3
S How to view backed up PSTs from Outlook 2007 in Outlook Classic's Folder pane Using Outlook 2
C Multiple accounts on Outlook.com? Using Outlook 3
J Need replacement for iTunes to locally (USB) sync. iPhone 17 to Classic Outlook 2024 Using Outlook 4
Thomas Fast Best way to manage incoming customer emails automatically in Outlook? Using Outlook 1
I Outlook 2024 Windows 11 Gmail - sudden log in problems Using Outlook 14
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
