Syntax for entering same statement as a reply
  • Thread starter Thread starter zoididge1
Z
zoididge1
Using Outlook 2007 on XP OS.
I'm new to Outlook macros and so tried to use my Word 2007 macro (see
following) as a standard reply to certain inquiries and it wont run. Once I
figure this one out, I'll be building about 10 other responses. Thanx for
any help.
sub MDLV_SST()
' MDLV_SST Macro
Selection.TypeParagraph
Selection.TypeText Text:="The major you have chosen, middle-level social
studies education, is currently in the curricular approval process. We
cannot guarantee that this major will be available by the time classes start
in fall 2010. As a result, we have placed you in secondary-level social
studies education. Please contact us with any questions or concerns."
Selection in this usage is a Word object, not an Outlook object. Therefore,
what you need is a way to get from the open Outlook message to a
Word.Selection object. That mechanism is the WordEditor property of the
Outlook Inspector window, which returns a Word.Document object. The article
at
http://turtleflock-ol2007.spaces.live.com/blog/cns!C1013F1F9A99E3D8!579.entry
shows how to You need to change your code so that a Selection object is
derived from the actual Outlook item that you want to modify.
You can also use the new Quick Parts feature in Office 2007 to save and
insert boilerplate text. You can look up Quick Parts in Outlook 2007 Help;
also see
http://turtleflock-ol2007.spaces.live.com/blog/cns!C1013F1F9A99E3D8!158.entry
Sue Mosher
"zoididge1" <zoididge1> wrote in message
news:826BE819-A097-4265-8637-5F661E0D4104@microsoft.com...
> Once I
> any help.
> sub MDLV_SST()
> ' MDLV_SST Macro
> social
> start
> End Sub
Thanx so much. Works for me.
> at
> also see
> > Sue Mosher
> > Once I
> > any help.
> > sub MDLV_SST()
> > ' MDLV_SST Macro
> > social
> > start
> > End Sub
Wotme Syntax for user defined field in VBA Using Outlook 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
J syntax Outlook VBA and Custom Forms 1
L Entering dates in Contacts and Calendar Using Outlook 4
A OL13 Calendar, won't allow entering 2 appointments consecutively Using Outlook 4
J Entering Contacts at Same Company Using Outlook 1
W Go to search field when entering a contact folder? Using Outlook 2
O Same email address, same person, names in so many ways Using Outlook 4
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
A Two Inboxes, Same Email? Using Outlook 3
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
N Move emails of same conversation to same subfolder Using Outlook 6
I get count of all emails with same conversation ID Outlook VBA and Custom Forms 2
R Shortcut for attaching the same file repeatedly Using Outlook 6
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
C How to copy same text header to multiple emails with custom text column Using Outlook 10
D Calendar - color coded items are now the same color Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
B Mail on both laptop and mobile at same time Using Outlook 2
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
L Delete code and commandbutton at the same time. Using Outlook 1
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
L IMAP and POP email in same Outlook system Using Outlook 1
A Use same BCM data in 2 offices BCM (Business Contact Manager) 3
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
S Searching contacts across GAL and local address book at same time Using Outlook 1
D Move email to same folder as the rest of the conversation Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
