Same email address, same person, names in so many ways
ofw62
I wonder whether there is solution of it: the same email address but the name is displayed in 7 ways...
1. first name, last name, no quotes, no email address
2. first name between quotes, no email address, like 'John'
3. first name and last name followed by email address between brackets, like: John Doe (john-at-provider.com)
4. first name and last name between quotes followed by email address, like : 'Jon Doe (john-at-provider.com)'
5. first name and last name no quotes followed by email address, like : Jon Doe (john-at-provider.com)
6. first name, no quotes, nothing else
7. email address
It is a bit complicated to get things in the right order, when sorting on name.
Is there a way to solve this?
Thanks for the above. Up front: right now, I merely checked 1 email address. This is because I wanted to check whether I had sent a specific attachment to that person on an earlier date. I then noticed the various ways the person was displayed in the "To" column, making it a somewhat difficult to find what I am looking for (also because of the many mails and because I wasn't sure when, could be months ago).
So, in this case it involves sent mail.
(Incoming mail is automatically redirected to a separate folder, using a rule)
It would be nice if Outlook would by default always (meaning, also retroactively) use the details in 'Contacts', as far as they are available of course.
I.e. take the email address and check what name goes with it in Contacts, use that one.
if the address is the same you can search or filter on the address. There is also an option to keep replies in the same folder with the original - this would work if you reply to messages already moved to a folder. The conversation view is useful to find replies too.
Thanks a lot for the tip!
Yes, I need to perform a search on the email address. That works fine.
Also thanks for your tip as "to keep replies in the same folder with the original"
i.e. tag the "When replying to a message that is not in the Inbox, save the reply in the same folder"-option
under File > Options > Mail > Save messages.
Also working fine.
P Different names for the same email address Using Outlook 1
A Two Inboxes, Same Email? Using Outlook 3
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
L IMAP and POP email in same Outlook system Using Outlook 1
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
D Move email to same folder as the rest of the conversation Using Outlook 1
K Save a received email in a mailbox subfolder which is the same as the @email Using Outlook 1
K Need to get OOO messages more than once for the same email box Using Outlook 2
C Send the same email at 1 pm Mon through Friday Outlook VBA and Custom Forms 1
T Emails - sending and receiving multiple copies of the same email Using Outlook 4
A Plugin registering the same email twice. Outlook VBA and Custom Forms 5
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
N Move emails of same conversation to same subfolder Using Outlook 6
I get count of all emails with same conversation ID Outlook VBA and Custom Forms 2
R Shortcut for attaching the same file repeatedly Using Outlook 6
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
C How to copy same text header to multiple emails with custom text column Using Outlook 10
D Calendar - color coded items are now the same color Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
B Mail on both laptop and mobile at same time Using Outlook 2
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
L Delete code and commandbutton at the same time. Using Outlook 1
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
A Use same BCM data in 2 offices BCM (Business Contact Manager) 3
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
S Searching contacts across GAL and local address book at same time Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
R View two Inboxfolders at the same time in split creen Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
D ActivitiesTab in OL2000 - same functionality in OL2013? Using Outlook 1
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
