View two Inboxfolders at the same time in split creen
rfcdvc45
Is it possible to set up a view where you have you Inbox folder on top and one of your Inbox subfolders on the bottom?
R Larger view Using Outlook 6
R Outlook 2021 change view Using Outlook 2
K Protected View - Files fail, no banner Using Outlook 4
S Inconsistent view of To-Do List Using Outlook 0
C View doesn't refresh (fields or formatting) Using Outlook 1
D Unable to view older emails in desktop app Using Outlook 0
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Using Outlook 1
