Inbox monitoring
Josh.moore
Hello. i work as an IT consultant and i have a client that wants software that will check to see how old an email is and if its older that a specified time he wants it to pull that email and put it in some one else email inbox. we already have a Round-robin email distribution software set up with this account. i have spent the better part of 3 hours searching for a software that does this. any help would be great
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 2
J Outlook inbox question Using Outlook 4
F Outlook 2021 Inbox delete icon missing Using Outlook 5
HarvMan Outlook 365 Inbox Font Using Outlook 8
M Start Outlook 365 at unified inbox Using Outlook 2
F Inbox moves on taskbar Using Outlook 1
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
S Format Inbox Using Outlook 0
P Emails assigned with a certain category (within a shared inbox) to be copied to a specific folder. Outlook VBA and Custom Forms 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
