Split reading view with history
jotoya
Outlook 365 32 bit
Is there a way that Outlook can show a top/bottom view of the selected message? Let me explain: If I click on a selected message I'd like to read, I thought there was a particular split view where the message currently select would display on the top of the split view while the bottom would show that email sender's history. So if I clicked on an email from John Smith, it would show that emails content in the top view and the bottom view would show all of John Smith's email to me. Make sense? I hope the attached graphics does a better job of explaining it than me.
Is this a "custom" view I can create? I thought it was already available.
Many thanks!
That was the People Pane from the Outlook Social connector. They killed the social connector a few years ago, but only recently killed the people pane. :(
A screenshot of it is in this article -
Thank you Diane. I appreciate the reply and information. Much appreciated.
C Split Screen Using Outlook 1
R View two Inboxfolders at the same time in split creen Using Outlook 1
K How to split large email when sending Using Outlook 1
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
V Reading/Posting in Newsgroups Using Outlook 1
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
A Received Date None after reading Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
J Reading outlook conatcts Outlook VBA and Custom Forms 1
D Getting Started - Reading attachment Outlook VBA and Custom Forms 4
J Reading E-Mails in VBA Outlook VBA and Custom Forms 1
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
