Reading E-Mails in VBA
  • Thread starter Thread starter John Clingeleffer
John Clingeleffer
I have an Access application that reads e-mail messages using MAPI and CDO. I
have a
site that uses Outlook with Groupwise 7.02. My VBA can access the Inbox and
cycle through the e-mails, but, while the VBA can see the e-mail subject, the
mody text (.Text property) is alays a zero length string, even though I can
see the text in the Inbox.
Problem only occurs at this one site. Fine on all other Outlook/Exchange
sites.
Any ideas.
GW MAPI provider (used by Outlook) is not of the best quality...
Can you access the Body property using the Outlook Object Model?
Dmitry Streblechenko (MVP)
"John Clingeleffer" <JohnClingeleffer> wrote in
message news:E29DCFE3-47EF-4C8A-A0E4-82820DDE88B7@microsoft.com...
> I
> have a
> and
> the
> can
> sites.
> Any ideas.
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
J Split reading view with history Using Outlook 2
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
V Reading/Posting in Newsgroups Using Outlook 1
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
A Received Date None after reading Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
J Reading outlook conatcts Outlook VBA and Custom Forms 1
D Getting Started - Reading attachment Outlook VBA and Custom Forms 4
T Blank Email in Reading Pane for Custom Form Outlook VBA and Custom Forms 12
C Getting reading pane horizontal instead of vertical Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
H Seeing mails after loosing access Using Outlook 1
Terry Sullivan Unwanted Duplicate E-Mails -- One with My Message and the Other Blank Using Outlook 0
S Sent e-mails roll back to previous draft state Using Outlook.com accounts in Outlook 2
