CustomTaskPane in PLace of Reading Pane
  • Thread starter Thread starter escamoteur
E
escamoteur
I just added a CustomTaskPane to my Exlorer window (Outlook 2007, COM Addin C#)
It works, but it strechtes ober the whole witdh of Outlook and not only below the Explorer View as the standard preview pane.
Is it possible to make the CustomPane look like a preview pane? Like it's now it just takes too much space.
I just watched a video showing how to use a FormRegion to replace the Preview pane based on the message class in VBA and VSTO. Is
this also possible to do with C# and a com-addin?
Best
Tom
A CTP will be docked at the bottom or sides of the Outlook window. You can't
make it replace only the area the preview pane occupies when preview is
displayed at the bottom.
You can use a form region without using VSTO. Some of my shared addins
written using C# use form regions.
"escamoteur" <mail@burkharts.net> wrote in message
news:711F8469-8FA0-4F49-94D8-EA7B510F819A@microsoft.com...
> Hi,
> Addin C#)
> Preview pane based on the message class in VBA and VSTO. Is this also
> Best
> Tom
Do you have any link how to use a form region to replace the preview pane?
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:#Pzsm7NeKHA.5228@TK2MSFTNGP06.phx.gbl...
> > Hi,
> > Addin C#)
>> Best
>> Tom
I found out how to do it. But as this Formregion is only displayed when an Item is selected, I think I will go for the Task Panel,
even if it's a bit too big.
Best
Tom
"escamoteur" <mail@burkharts.net> schrieb im Newsbeitrag news:6CFBA85E-6C13-4455-9E95-8F634CEAE706@microsoft.com...
> Best
> Tom
> " - " <kenslovak@mvps.org> schrieb im Newsbeitrag news:#Pzsm7NeKHA.5228@TK2MSFTNGP06.phx.gbl...
> > A CTP will be docked at the bottom or sides of the Outlook window. You can't make it replace only the area the preview pane
> > occupies when preview is displayed at the bottom.
>> You can use a form region without using VSTO. Some of my shared addins written using C# use form regions.
>> "escamoteur" <mail@burkharts.net> wrote in message news:711F8469-8FA0-4F49-94D8-EA7B510F819A@microsoft.com...
> >> Hi,
> >> Is this also possible to do with C# and a com-addin?
>>> Best
>>> Tom
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
L However, before you place an order, you want to pick out whether or not you want the to Using Outlook 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Search and In-Place Archiving Using Outlook 0
piusg 2013: Place custom view on the ribbon Using Outlook 3
anoble1 Can you create a rule once an email moves to the Vault Inbox to another place? Using Outlook 0
Z Automatically adjust Outlook Reading Pane from bottom to right depending on portrait or landscape window Using Outlook 1
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
J Split reading view with history Using Outlook 2
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
V Reading/Posting in Newsgroups Using Outlook 1
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
A Received Date None after reading Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
R Proof Of Looping Bug in Reading Outlook Inbox From Access? Outlook VBA and Custom Forms 2
L Reading another mailbox Address Outlook VBA and Custom Forms 2
S Macro for Viewing mails one after the other in the Reading Pane Outlook VBA and Custom Forms 2
N Reading Recipients in a folder Outlook VBA and Custom Forms 1
J Reading outlook conatcts Outlook VBA and Custom Forms 1
D Getting Started - Reading attachment Outlook VBA and Custom Forms 4
