Larger view
RonP
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    windows 11
Outlook version:     classic outlook
Email type or host:    POP,
For some reason, my Outlook 365 Inbox and messages were reset to 8pt Segoe UI. I see how I can set each page to a larger font. Is there a way to make the letters larger in each view universally? My eyes are getting tired reading that small font. Desktop display or Chrome Zoom doesn't seem to help.
Thanks, Ron
You can zoom in the reading pane for HTML messages - hold Ctrl and roll the mouse wheel or click on the % slider in the lower right of the reading pane (under the to-do bar if using). If you have a subscription (and possibly in some newer perpetual versions) - you can click on the % (110% in the screenshot) and check the box to "Remember my preference".
Plain text uses the font settings - File > Options > Mail > Stationery & fonts.
[ATTACH
I see the zoom control, but I can't change it by clicking on it or using the control/scrolling. It shows it is set to 10%.
Sorry I didn't see this earlier - is it greyed out?
Make sure the Reading Page is enabled?
With Reading Pane off:
With Reading Pane on:
Open an email and from the main menu choose Zoom.
Thanks, Ron
I ran into something similar after an Outlook update. If every folder suddenly switched to the same small font, it almost feels like the view settings were reset. As far as I know, there isn't a single global option that changes every view at once in Classic Outlook, which is frustrating.
Hopefully someone knows a registry tweak or a way to apply the font settings across all folders, because changing them one by one is definitely not practical.
If you are talking about the item listings details in Folder Views. e.g.
To reset all Views to default: Windows Key + r (open the Run dialog), enter Outlook.exe /cleanviews in the Open box and click ‘OK‘. This will erase any Custom Views you have created and reset all Standard Views to their initial defaults.
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
C Export to excel missing items, but a larger total? BCM (Business Contact Manager) 6
J Best way to move form old to new, larger pst? Using Outlook 2
S How to view backed up PSTs from Outlook 2007 in Outlook Classic's Folder pane Using Outlook 11
R Outlook 2021 change view Using Outlook 2
K Protected View - Files fail, no banner Using Outlook 4
S Inconsistent view of To-Do List Using Outlook 0
C View doesn't refresh (fields or formatting) Using Outlook 1
D Unable to view older emails in desktop app Using Outlook 0
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
