Enabling VBA
  • Thread starter Thread starter Jared Bonow
Jared Bonow
Yesturday I was creating custom toolbars in outlook (everything was working perfectly) and saw something on Microsoft.com about clicking "reset menu and toolbar usage data". I clicked that button and now Macros, Security and Visual Basic Editor won't even open up when I try to access them. How do I get into VBA again???.
Shut down Outlook, make sure that the Windows Task Manager shows Outlook.exe
has quit, then restart Outlook.
Sue Mosher
"Jared Bonow" <jared[dot]bonow[at]bench[dot]com> wrote in message
news:epDPJnWXKHA.5368@TK2MSFTNGP02.phx.gbl...
> access them. How do I get into VBA again???. Submitted using
> https://forums.slipstick.com
It still is not working. I even ended the process from task manager. Any other suggestions?
suemvp wrote on Wed, 04 November 2009 12:39
> > Sue Mosher
Try restarting the computer.
Sue Mosher
news:ObW6ffXXKHA.3676@TK2MSFTNGP05.phx.gbl...
> other suggestions?
> > Outlook.exe has quit, then restart Outlook.
> > > to access them. How do I get into VBA again???. Submitted using
S Error after enabling 2-step authentication in Outlook.com/Outlook 2013 Using Outlook.com accounts in Outlook 1
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
R Enabling OutlookAnywhere in ClientAccess role causes inaccessible RemoteDesktop Gateway Server Exchange Server Administration 2
