Body disappears in 2002 when creating an item from a saves msgattachment
  • Thread starter Thread starter Peter Marchert
P
Peter Marchert
I try to reference a message which is attached to an e-mail. I use the
following code to save the attachment first and then set a reference
to it:
Sub test()
Dim objReply As Outlook.MailItem
Dim objItem As Outlook.MailItem
Set objReply = Outlook.ActiveExplorer.Selection(1)
Call objReply.Attachments.Item(1).SaveAsFile("C:\test1.msg")
' open "C:\test1.msg" via windows explorer -> body is ok
Set objItem = Outlook.CreateItemFromTemplate("C:\test1.msg")
Debug.Print objItem.Body ' -> body is ok
Call objItem.SaveAs("C:\test2.msg", olMSG)
' open "C:\test2.msg" via windows explorer in 2002 -> body is
blank
' open "C:\test2.msg" via windows explorer in 2003/2007 -> body is
ok, but no PR_BODY property exists
Set objItem = Nothing
Set objReply = Nothing
As you can see in the comments the body disappears when opening the
saved msg file in 2002.
If I use RDO the message is completely empty (e. g. subject):
Sub test2()
Dim objRDOMail As Object
Dim objRDOAtt As Object
Dim objRDOSession As Object
Set objRDOSession = CreateObject("Redemption.RDOSession")
objRDOSession.MAPIOBJECT = Outlook.Session.MAPIOBJECT
Set objRDOMail = objRDOSession.CreateMessageFromMsgFile("C:
\test1.msg")
objRDOMail.SaveAs "C:\test2.msg"
' open "C:\test2.msg" via windows explorer in 2002 -> message is
blank
I want to ask if there is a workarround or a simplier way to get the
reference to an attached message.
Peter
Re: Body disappears in 2002 when creating an item from a saves msg attachment
Hi Peter,
with RDO object you can directly open the attachment, you don't need to save
it as a file. Does that workaround the empty body?
Best regards
Michael Bauer
Am Fri, 30 Oct 2009 04:09:04 -0700 (PDT) schrieb Peter Marchert:
> Hello,
> to it:
> Sub test()
> blank
> End Sub
> Sub test2()
> \test1.msg")
> blank
> End Sub
> Thanks
> Peter
On 3 Nov., 21:21, "Michael Bauer " <m...@mvps.org
wrote:
Hello Michael,
thanks for your reply.
I'm not sure. I tested a lot the last days but finally I have no
solution (the users of 2002 gets a message to do something by hand).
The code is not easy and at least I think with RDO the body was ok,
but I cannot send the message without error (I replace attachments in
the attached message with OOM after the send event had fired).
May be I try something at a later time with RDO, but it seems to me I
have to rewrite great parts of the code to implement this.
Peter
> Hi Peter,
> > Best regards
> Michael Bauer
> > Hello,
> > to it:
> > Sub test()
> > blank
> > End Sub
> > Sub test2()
> > \test1.msg")
> > blank
> > End Sub
> > Thanks
> > Peter
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
B 10 Practical Tips for Healthy and Sustainable Weight Loss10 Steps to Achieving Your Dream Body Outlook VBA and Custom Forms 0
G Retaining Tabs in outlook body Using Outlook 2
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
K Incorporate selection from combobox into body of email Outlook VBA and Custom Forms 0
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
Beeto Replace a string in body Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
