Re:Running a Macro when email arrives
  • Thread starter Thread starter Gardos Catalin
G
Gardos Catalin
Hello everybody. I trie to make a macro that print my incoming email that
contains in subject word "Comanda online".
This is the macro:
Private Sub Application_NewMail()
CheckMail
Public Sub CheckMail()
Dim OlApp As Outlook.Application
Dim Inbox As Outlook.MAPIFolder
Dim oOApp As Outlook.Application
Dim oOMail As Outlook.MailItem
Dim InboxItems As Outlook.Items
Dim Mailobject As Object
Dim Subject As String
Set OlApp = CreateObject("Outlook.Application")
Set Inbox = OlApp.GetNamespace("Mapi").GetDefaultFolder(olFolderInbox)
Set InboxItems = Inbox.Items
For Each Mailobject In InboxItems
If Mailobject.UnRead Then
Subject = Mailobject.Subject
If Subject = "Comanda online" Then
Mailobject.PrintOut
Mailobject.UnRead = False
Set OlApp = Nothing
Set Inbox = Nothing
Set InboxItems = Nothing
Set Mailobject = Nothing
It's working, but i want to print only the body of the email.
Is this possible ?
Hope to reply to me.
url:http://www.ureader.com/msg/1081942.aspx
Re: Running a Macro when email arrives
I'd probably create a Word document, insert the body of the email, and then
print the document instead of the email.
Best regards
Michael Bauer
Am Mon, 4 Jan 2010 12:52:58 +0800 schrieb Gardos Catalin:
> This is the macro:
> CheckMail
> End Sub
> Mailobject.PrintOut
> End If
> End If
> Next
> Set OlApp = Nothing
> Set Inbox = Nothing
> End Sub
> Is this possible ?
> Thank you.
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
H running multiple macros at once Outlook VBA and Custom Forms 0
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
S CSCANPST To Automate Running SCANPST.EXE Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
A running code after the new inspector is visible Outlook VBA and Custom Forms 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
B Phantom VBA Running Outlook VBA and Custom Forms 1
M If loop not running Outlook VBA and Custom Forms 1
D Troubleshooting rule/script not running Outlook VBA and Custom Forms 5
P How to use a form from a rule running on the inbox Outlook VBA and Custom Forms 1
Q Running the Database from a Server BCM (Business Contact Manager) 7
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
S Outlook rules not running automatically Using Outlook 11
D Request help with a macro for forwarding email Outlook VBA and Custom Forms 5
