Outlook opens in a small window
  • Thread starter Thread starter JnVGray
JnVGray
This is probably easy to fox but I can't figure it out. When I open Outlook
(2007) or restore it from being minimized it opens in a small window and I
have to click maximize every time. This didn't happen until I installed
Windows 7. Any suggestions?
Don't maximize it. Instead, drag the window's borders larger. Windows will remember this larger size.
Right click on the Outlook icon on your desktop and select Properties and in the Run
box select Maximized. Hit Apply and back out. Open Outlook. Does it open maximized
Peter
Do you want it maximized or just bigger?
The usual fix is to resize the window & close it. An old Windows trick for
setting window sizes also works with Outlook 2007: hold down the shift key
and double click in the top left corner of the window. This will close the
window and when you reopen, it should remember the size and location.
You need to verify that outlook closed completely in task manager, processes
tab. If it's left running, its being forced closed and the changes won't
stick.
Had the same problem - outlook opened in a small window but THOUGHT it was in a large window. Every time I had to restore down then maximize to get full screen. Here's how I fixed it. Open Outlook and maximize it. Right click taskbar "Show windows stacked" Close Outlook. Open Outlook - opened full screen for me. Right click task bar undo stacked. Tada!
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
B IMAP folders don't update when Outlook 365 opens Using Outlook 0
Z Outlook opens minimized, won't maximize Using Outlook 2
C Outlook 2007 Contact Card opens in margin of screen where I can't see it Using Outlook 3
S Must accept EULA everytime Outlook 2003 opens in Windows 7 Using Outlook 3
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 2
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 4
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
B Sync Google Calendar with Outlook Using Outlook 5
