add note to body or notes
  • Thread starter Thread starter Joel Allen
Joel Allen
Outlook 2003 SP1
The following script adds a note to existing notes in the notes field.
Sub CommandButtonNewEntry_Click()
Item.Body = Now() & " " & pCurUserName & ": " & vbCrLf & vbCrLf & Item.Body
My problem is that all the formatting is lost and turns it to plain text.
Any ideas on how to keep the formatting that exists in the notes field?
Thanks, Joel
Depends on the item. If it's an email, it's probably html, so read/write the
stuff from/into the HTMLBody property.
Best regards
Michael Bauer
Am Wed, 17 Feb 2010 07:42:20 -0800 schrieb Joel Allen:
> Outlook 2003 SP1
> Hi,
> '---------------> Sub CommandButtonNewEntry_Click()
> On Error Resume Next
Item.Body
> End Sub
> Thanks, Joel
No, it's a custom Task item. Any ideas?
"Michael Bauer " <mb@mvps.org> wrote in message
news:sz4da217ierw$.12ml4yee8g5yf.dlg@40tude.net...
> the
> > Best regards
> Michael Bauer
> > Outlook 2003 SP1
>> Hi,
>> '---------------> > Sub CommandButtonNewEntry_Click()
> Item.Body
> > End Sub
>> Thanks, Joel
Tasks and appointments store the body in RTF.
You would need to use either Extended MAPI (C++ or Delphi only) or
<plug>Redemption (url below) - set the SafeTaskItem.RtfBody property</plug
Dmitry Streblechenko (MVP)
"Joel Allen" <joelallen123@hotmail.com> wrote in message
news:uk%23FYe$rKHA.1476@TK2MSFTNGP02.phx.gbl...
> > the
>> > > Best regards
> > Michael Bauer
> >> Outlook 2003 SP1
>>> Hi,
>>> '---------------> >> Sub CommandButtonNewEntry_Click()
> > Item.Body
> >> End Sub
> >> text.
>>> Thanks, Joel
Redemption seems like the solution to me. If I bought it and installed it
on my computer, will the code still work on other users computers, or do I
need to install redemption on everyone's computer?
"Dmitry Streblechenko" <dmitry@dimastr.com> wrote in message
news:uo%23KqCCsKHA.5568@TK2MSFTNGP05.phx.gbl...
> property</plug
> >> the
>>> > >> Best regards
> >> Michael Bauer
>>>> Outlook 2003 SP1
>>>> Hi,
>>>> '---------------> >>> Sub CommandButtonNewEntry_Click()
> >> Item.Body
> >>> End Sub
> >>> text.
>>>> Thanks, Joel
The dll woudl need to be installed on every computer where it is used. As
simple as copying the dll to a local folder and registering it with
regsvr32.exe will work.
news:OZIYa9CsKHA.5568@TK2MSFTNGP05.phx.gbl...
> > property</plug
> >>> read/write the
>>>> > >>> Best regards
> >>> Michael Bauer
>>>>> Outlook 2003 SP1
>>>>> Hi,
>>>>> '---------------> >>>> Sub CommandButtonNewEntry_Click()
> >>> Item.Body
> >>>> End Sub
> >>>> text.
> >>>> field?
>>>>> Thanks, Joel
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
T Add Account Using Outlook 1
