Required and oprtional attendees
  • Thread starter Thread starter JP Ronse
JP Ronse
Hi All,
I am creating meetingrequests with Excel VBA. Part of the code below.
Set gobjOutlook = GetObject(, "Outlook.application")
Set gobjAppointment = gobjOutlook.CreateItem(olAppointmentItem)
With gobjAppointment
> MeetingStatus = olMeeting
> .. and all other stuff
Set gobjMailAddress = .Recipients.Add(gstrAddressee)
gobjMailAddress.Type = olOptional
Set gobjMailAddress = .Recipients.Add(gstrOptionalAddressee)
Sometimes the optional addressee becomes a required one and sometimes they
remain optional.
I'm not sure why this happen but think that it has something to do with the
way I specify the optional attendees.
- john.doe@thisforum.com looks as working always correctly
- John Doe works also correctly when known in my addressbook
- I goes from time to time wrong when John Doe is known in the addressbook
as John Doe (Outlook Forum)
Can soemone confirm this or tell me more about this? Thanks in advance.
With kind regards,
JP
If you supply a name instead of an email address and the name can be
ambiguous or doesn't match what's in an address book the recipient may not
resolve. That shouldn't change the recipient type.
See if this works better. Here is the equivalent of each type of meeting
recipient versus the recipient type:
Required To
Optional Cc
Resource Bcc
Set those and see if things work better, but avoid ambiguous recipients.
"JP Ronse" <fb893760@skynet.be> wrote in message
news:ejGPhI%230KHA.5996@TK2MSFTNGP05.phx.gbl...
> Hi All,
> .MeetingStatus = olMeeting
> ... and all other stuff
> End With
> remain optional.
> the way I specify the optional attendees.
> With kind regards,
> JP
Hi Ken,
I've tried your suggestion and it looks indeed better. Thanks for this.
With kind regards,
JP
news:equq44M1KHA.3652@TK2MSFTNGP04.phx.gbl...
> Required To
> Optional Cc
> Resource Bcc
> > Hi All,
>> End With
> > they remain optional.
> > addressbook as John Doe (Outlook Forum)
>> With kind regards,
>> JP
V Why is "Value Required" checkbox greyed out for Dates? Outlook VBA and Custom Forms 2
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
J No response required when delegate arranging meeting Using Outlook 0
A Stopping the required attendee invites Using Outlook 1
M VBA SWcript Help Required Using Outlook 1
K What’s required to use BCM as a collaborative CRM platform? BCM (Business Contact Manager) 1
Diane Poremsky Help required for multiple identities when switching from POP to IMAP Using Outlook 1
J Outlook Invites automatically adding 'Required Attendees' Using Outlook 1
B Compile error: Object required Outlook VBA and Custom Forms 2
C Update Notes for Meeting Attendees Using Outlook 8
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
E Can't invite attendees Using Outlook 1
C Unable to see meeting attendees Outlook 2010 Using Outlook 5
W Add Attendees is greyed out on Appointment Using Outlook 2
I Does forwarded meeting invite gets sent to all the Attendees and Organizer? Exchange Server Administration 0
J Ability to notify attendees when canceling past meeting is gone Using Outlook 1
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
S How do I edit an attachment in an invite without notifying the attendees? Using Outlook 2
M Deleted Meeting but didnt send notice to attendees, how to fix?? Using Outlook 1
M programmatically make all Appointmentitem olResource Attendees unsendable Using Outlook 1
S Adding attendees and only send update to them Using Outlook 2
M Create editable meeting request with attendees from .ics Outlook VBA and Custom Forms 3
