Autocomplete, although enabled, does not complete names in TO:
  • Thread starter Thread starter The Houstonian
The Houstonian
I have turned on my Autocomplete, but it erases my ames sent in the TO: box,
everytime I turn off m computer. Help!
Home or corporate computer? Reason I ask is that in a corporate
environment, if the site has implemented mandatory profiles or is using
something that "freezes and restores" the computer to a certain
configuration at startup would account for this. What would be happening is
that the nickname file is being deleted between logons to the operating
system.
"The Houstonian" <The Houstonian> wrote in message
news:EFCE08B7-517E-45D2-A1E9-98F8BF195603@microsoft.com...
>box,
What version of Outlook are you using? What operating system are you
running? Are you exiting Outlook BEFORE you turn off the computer?
> box,
I have the same problem. Autocomplete only remembers the names during the current session. When I close outlook (prior to turning the computer off) I lose everything. Home computer.
Jerry
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
V Autocomplete not working on new email account Using Outlook 4
G Autocomplete adds suspicious "@unknown.email" to selected contacts Using Outlook 1
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M email autocomplete broke.. Using Outlook 5
C Autocomplete losing some (not all) addresses Using Outlook 6
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
V Outlook 2013 - transfer autocomplete data Using Outlook 4
A Autocomplete issue Using Outlook 6
Michael Durthaler Outlook 2013 Autocomplete File Is Infected Using Outlook 1
U Autocomplete not working Using Outlook 5
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
G Outlook 2013 AutoComplete Limit Using Outlook 3
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
J autocomplete in "To" field does not work for display names Using Outlook 8
U Imported contacts to appear in Autocomplete Using Outlook 1
V Outlook 2010 Autocomplete Using Outlook 7
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Help with random numbers in autocomplete emails Exchange Server Administration 3
S Can’t see messages within a folder although they defiantly exist Using Outlook 2
M Always Enabled Outlook VBA and Custom Forms 3
B Add-in "always enabled" but Outlook 13 won't open Using Outlook 7
J BCM Crashing with Add-in Enabled in User Mode BCM (Business Contact Manager) 2
L Open an Exel Macro Enabled Worksheet Using Outlook 4
D Show this folder as an e-mail Address Book is enabled but I want to disable Using Outlook 2
G Security-enabled Distro Group Members Can't Access Associated Group Mailbox Using Outlook 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
