how to save incoming mail in TRUE csv format
  • Thread starter Thread starter Matt
Matt
I have a script in Outlook 2007 that automatically saves incoming emails to a
folder as a txt. Simply changing my code to olCSV does not comma separate the
values. How can i convert this to a csv format? Is it possible?
Obviously I'm a real newbie. Thanks in Advance or all/any help!
here's my code:
Sub saveemail(myItem As Outlook.MailItem)
myItem.SaveAs "c:\mail\" & myItem.Subject & ".txt", olTXT
Matt
Outlook has no native ability to turn text into a csv file. If you want to do
more than save the message as a .txt file, you'll have to add your own code
to parse the message content or parse the .txt file. Either way, only you
know what you have in mind. It's not clear at all from your description what
"values" you want saved in .csv format.
Sue Mosher
> here's my code:
> End Sub
> Matt
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
M Save incoming Email as .html file with name of subject line Outlook VBA and Custom Forms 3
J Save Dialog Outlook VBA and Custom Forms 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
Sandgroper48 Save vbaProject Outlook VBA and Custom Forms 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
