delete appointmentitem permanently using redemption
  • Thread starter Thread starter sd
sd
hello
Is there any way to delete appointmentItem permanently using
redemption?Redemption.SafeAppointmentItem doesn't have delete
method.please provide a code snippet if possible.
Make sure the item is saved so it has an EntryID, get the EntryID and use
that with an RDOSession object to call RDOSession.GetMessageFromID(). That
returns an RDOMail object, call that object's Delete() method.
' assume the Outlook appointment is oAppt:
If oAppt.Saved = False Then
oAppt.Save
Dim id As String
id = oAppt.EntryID
Set oAppt = Nothing
Set oSafeAppt = Nothing
Set oRDO = CreateObject("Redemption.RDOSession")
oRDO.MAPIOBJECT = olApp.GetNameSpace("MAPI").MAPIOBJECT
Dim safMail As Redemption.RDOMail
Set safMail = oRDO.GetMessageFromID(id)
safMail.Delete
"sd" <dshubhangi@gmail.com> wrote in message
news:5e267549-96a0-4c57-bf48-172177d1cc90@x29g2000prf.googlegroups.com...
> hello
> Thanks
F Outlook 2021 Inbox delete icon missing Using Outlook 5
T Cannot delete a calendar Using Outlook 0
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
A Outlook 365 Delete entries in title field, address book Using Outlook 0
D Delete Outlook emails from MS server Using Outlook 17
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
G Automatically delete email when a condition is met Outlook VBA and Custom Forms 1
M Shift Delete doesn't delete email from server Using Outlook 3
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
O How to delete a forum post? Using Outlook 4
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
O Delete duplicate emails - subscription notifications Using Outlook 5
L Email Read and Delete Outlook VBA and Custom Forms 4
H Delete Calendar Entries in Using Outlook 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Outlook 2016 cannot delete, email showing in root Exchange Server Administration 5
