Subject Line Problem - Multiple RE and FW
DavidStern
My understanding is that Outlook (2010) removes Re: and Fwd: and replaces them upon sending an email.
In my case however it is not doing this it simply adds more and more to the subject line and I end up with
RE Fwd FW or RE RE - well you got the message
I have searched the web upside down and can't find anything about this issue.
Let me pre-empt and say that there is not a leading space or anything like this causing a problem
Appreciate any assistance
David
Are you 100% sure there is not a leading space or other character? Because absent that, all current versions of Outlook will not add extra re's to the subject. Also, if there are multiple Re's in the subject when youo received it, it probably won't remove those. It only affects the one that would be added by you.
http://www.outlook-tips.net/2005/646/tip-230-why-outlook-doesnt-remove-re-re-re/
Absolutely 100% positive that there are no leading spaces
I do have an Add-In Sperry Software and even disabling that doesnt change the problem just in case that is the next question.
It also adds a Re to each Subject Line - is that normal?
Try safe mode - the results will likely the the same though.
Can you forward me one as an attachments? I'll see if i can see anything that sticks out. (Assuming the forward doesn't screw it up.)
The Re's don't have colons - RE RE Share Margin Loan - outlook needs a colon to identify the prefix.
Why it has no colon is unknown. I can't tell from looking at the message or header - it goes through messagelabs for spam filtering and gmail but neither should remove the colon.
V Encoding problem in subject line Using Outlook 0
F Auto changing email subject line in bulk Using Outlook 2
D Prompt to prefix subject line whenever sending an email Outlook VBA and Custom Forms 3
2 How to get rid of the "Emailing:" prefix in the subject line Using Outlook 1
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
J Marco in search of text in subject line Using Outlook 8
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Can't see full text in From and Subject line Using Outlook 1
D dropdown list in new email in subject line Using Outlook 4
N Rename Subject Line with Email Content Outlook VBA and Custom Forms 3
Diane Poremsky Editing the Subject Line in Outlook Using Outlook 0
Aussie I Change the Subject Line ... but after it is moved the subject has reverted Using Outlook 1
Diane Poremsky Add a file number or keyword to the subject line of messages Using Outlook 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
B VBA to prepend subject line Using Outlook 0
M Outlook adds strange characters inserted into the Subject Line Using Outlook 2
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
D RTRIM a subject line for grouping purposes Outlook VBA and Custom Forms 1
J Create Calendar Alert Event form Mail Subject line? Using Outlook 4
Phillip Strip Text from Subject Line Outlook VBA and Custom Forms 3
C Autofill subject line in appointment from options selected in combobox Using Outlook 6
J Create an appointment from Contact list with the Company name in the Subject line Using Outlook 1
C Save outlook attachments and rename/append files with identifier from subject line Outlook VBA and Custom Forms 3
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
T Point Subject Line to Data Field Using Outlook 1
R Edit Subject Line of Meeting Invitation? Using Outlook 1
W Macro to add a word in Subject Line Using Outlook 1
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
A Change subject line of external software using outlook. Using Outlook 1
F VB Script, remove text from subject line when forwarding Using Outlook 22
