Inserting a PPT/PDF into the message body
Lorelai
I have created a ppt of a status report. I am trying to find the best way to place this in an email message to be sent out to all recipients. I was originally saving the ppt as a png image and inserting it in the message, but learned that by doing this, my links became inactive. Is there a way to somehow insert the ppt in whatever format is needed so that it is not an attachment, but is viewable with active links right in the message body? I am using Outlook exchange 2007.
Thank you for your help!
lorelai
D Inserting sender name and address with vba Outlook VBA and Custom Forms 1
W Inserting Additional Email Address Outlook VBA and Custom Forms 4
D Using Libraries when inserting a file in Outlook 2013 Using Outlook 1
B Outlook 2007 - Slow opening folders when inserting attachments Using Outlook 2
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
W inserting activeX/user control into form Outlook VBA and Custom Forms 1
H C# inserting word document with formatting into outlook message Outlook VBA and Custom Forms 1
R Inserting a hyperlink in the bod of an outlook appt. Outlook VBA and Custom Forms 13
K Inserting text from a macro Outlook VBA and Custom Forms 1
J add a delay to VB that automatically prints PDF's Outlook VBA and Custom Forms 5
R File not found when sending email with attached pdf file Using Outlook 2
M Save as Adobe PDF misses inline graphics Using Outlook 0
B Outlook tasks and PDF Using Outlook 4
Commodore PDF attachments started to open in Edge Using Outlook 0
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
X Outlook automation pull from PDF Using Outlook 5
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky Save Outlook Email as a PDF Using Outlook 0
B Auto open PDF Outlook VBA and Custom Forms 0
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
R how to open a pdf file with a known password Outlook VBA and Custom Forms 1
V Emails, pdf.s ocr - oh my Using Outlook 1
E PDF Import Using Outlook 1
D Save pst and attachments as a PDF File Outlook VBA and Custom Forms 3
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
J Automatically Print PDF When They Are Received Using Outlook 4
J How to open PDF attachement upon arrivel new mail Using Outlook 20
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
J Opening a web URL that points to PDF file... Outlook VBA and Custom Forms 7
G pdf format in access 2007 Outlook VBA and Custom Forms 1
W Displaying custom properties of a PDF DocumentItem Outlook VBA and Custom Forms 3
