Calculated Date Field In Message Body
I am trying to create a template message in Outlook 2010. In the message, there is a date that will need to be changed every time I open the template. The date needs to change to 9 business days from the date the message is sent (from when it is opened i.e. if I send the message on March 25th 2013, the date will read April 5th, 2013) and I would like it to update automatically each time the message is opened. I have searched for any way to do this but any answer I come up with will work in Word but not Outlook. Does anyone have an answer for this?
Thanks for your time!
Q Sorting tasks by calculated field - automatically update task-fiel Outlook VBA and Custom Forms 9
T POP Sent Folder Synchronization Issue & Inbox Email Date Display Disorder Using Outlook 1
T Outlook 2010 Emailed folder but no 'From-To-Subject' information. Date okay. Using Outlook 12
F Outlook 365 Group INBOX by date but not by date and time Using Outlook 1
S Displaying Date Value In Formula Outlook VBA and Custom Forms 6
CWM330 Wrong Date Using Outlook 4
R unable to filter tasks when start date is on or before today Using Outlook 4
S Combination Field (Date Format) Outlook VBA and Custom Forms 0
U How can the Received date be edited? Using Outlook 0
D This folder up to date vs all folders up to date Using Outlook 1
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
P Short Date Format when typing in a task Using Outlook 2
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
V 10 Years calenders -single date together Exchange Server Administration 8
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
X If you change expiration date of repeated task it dupplicates Using Outlook 1
D Archive by receive date not working Using Outlook 2
V Making a Date field mandatory in outlook form Outlook VBA and Custom Forms 2
L Ctrl Alt d date stamp use Using Outlook 1
Witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
O Tasks - Is there a postponed date column? Using Outlook 7
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
F Finding Meetings/Tasks in a date range Using Outlook 1
J Old unread emails on current date (MDaemon Server) Using Outlook 1
