VBA to block senders
Wotme
Outlook 2019 32-bit
Using pre-set rules I delete certain emails that I consider spam, but I would also like to block those senders at the same time.
Does anyone know if its possible using VBA code or otherwise, it would be really helpful
Chris
As far as I know, the safe and blocked lists are not supported in the object model so you can't use a script to update them. Sorry. You could use a script to save the address to a text file then copy that to the blocked list, but keep in mind that the blocked /safe lists support a limited number of entries. If the rule is working, you should use it over adding names to the list, especially spammer domains as they change often.
S Works individually with MFCMAPI but not bulk with VBA script... Outlook VBA and Custom Forms 2
