Difficult Oulook Crashing Problem
Fixer1234
I've been wrestling for months with several problems of Outlook 2007 crashing, which I assume are probably related. I've already done extensive research and tried every fix I could find. Hoping someone has a new idea to try.
Symptoms:
  1. If Outlook writes to the PST file, it becomes corrupted. Need to repair the file daily. Run scanpst typically 3-4 times until it reports no errors. The PST file is not accessed by anything but Outlook and scanpst (no third-party software corrupting it).
  2. Dismissing a calendar reminder crashes Outlook. Not dismissing a reminder sometimes crashes Outlook if the reminder window remains open for a long period (Outlook actively refreshes it).
  3. If the reading pane is open and the first message automatically viewed in a folder is a calendar appointment invitation message, Outlook crashes. If a non-calendar message is auto-opened and then the appointment message is selected, Outlook doesn't crash.
What I've tried:
  • Everything on the Microsoft web page: Outlook 2007: Troubleshooting Outlook Crashes http://support.microsoft.com/kb/2000071
  • Ran the stability diagnostic tool and OffCat (no problems found)
  • No malware; extensive checks.
  • All updates were originally current. There is actually evidence that part of the problem may relate to updates, so I rolled back all updates to roughly Fall 2013, when the problems started. The problems got progressively worse in recent months, to the point that Outlook would not load without immediately crashing even in safe mode. I reinstalled Outlook with minimal features enabled. It has been better but still crashes.
  • Starting in safe mode or with various command line switches for a clean start often helps temporarily. I suspect the benefit is from disabling the reading pane at start-up.
  • All plugins are disabled. The active email AV software is disabled.
  • Windows (7/64 Home) has been tested OK. No hardware or operating system problems have been detected.
  • The problem does not relate to the reminder chime (chimes fine and doesn't crash until later when the reminder is dismissed).
  • Outlook is not running in compatibility mode.
  • The user account has administrative privileges but Outlook is not opened with explicit administrative privileges.
  • This is a stand-alone computer (no server involved).
Outlook ran with no problems until roughly Fall of 2013. Heavy-duty crashing started a few months ago. I can think of no significant changes on the computer other than Microsoft updates.
Has anyone else experienced these problems or have a new idea on a solution? I'm close to ditching Outlook and trying something like Thunderbird.
C Whose brilliant idea was to make it more difficult to scroll in Outlook? Using Outlook 0
S too difficult of a question to google Using Outlook 2
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
M Following a refresh of computer (win8.0) conflicting oulook accounts Using Outlook 2
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
R Copy additional IMAP accounts into Oulook 365 Account Exchange Server Administration 4
S Oulook view settings ( NO PST) Using Outlook 0
L Oulook Size On a Desktop Screen Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P Oulook 2010 very slow Using Outlook 2
P Problem: Favorites not persisting. (Oulook 2010) Using Outlook 1
J Oulook 2010 Shared Calendar Syncing Using Outlook 1
L Oulook 2003 Form upgraded to 2007 Outlook VBA and Custom Forms 3
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
P Questions On Crashing, Sluggish, and Configurations Using Outlook 1
C Outlook (365) is crashing as soon as its opened Using Outlook 2
L Outlook Office 365 cached mode crashing Using Outlook 0
E Gmail crashing Outlook Using Outlook 2
C Outlook Crashing on Specific BCM Lead File BCM (Business Contact Manager) 2
J BCM Crashing with Add-in Enabled in User Mode BCM (Business Contact Manager) 2
D outlook keeps crashing with cLucene error Using Outlook 2
J Checking PST File Keeps Crashing Using Outlook 2
U Need a help please Outlook 2007 crashing Using Outlook 2
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
Q Constant crashing BCM (Business Contact Manager) 2
P pasteface method crashing outlook Outlook VBA and Custom Forms 7
B RE: Outlook 2007 - SMS Link (mobile text) crashing outlook Outlook VBA and Custom Forms 1
