Oulook view settings ( NO PST)
I have custom view settings that will stick for several days and then be gone and have to be re-created. All the information I find on view settings say that they are stored in a PST file, but I do not have a PST. I am working in NON-cached outlook with exchange 2010. Can anyone tell me where view settings would be stored in an enviroment without PST's and how to ensure that those settings stick?
thank you,
Susan
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
M Following a refresh of computer (win8.0) conflicting oulook accounts Using Outlook 2
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
R Copy additional IMAP accounts into Oulook 365 Account Exchange Server Administration 4
F Difficult Oulook Crashing Problem Using Outlook 1
L Oulook Size On a Desktop Screen Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P Oulook 2010 very slow Using Outlook 2
P Problem: Favorites not persisting. (Oulook 2010) Using Outlook 1
J Oulook 2010 Shared Calendar Syncing Using Outlook 1
L Oulook 2003 Form upgraded to 2007 Outlook VBA and Custom Forms 3
R Larger view Using Outlook 6
R Outlook 2021 change view Using Outlook 2
K Protected View - Files fail, no banner Using Outlook 4
S Inconsistent view of To-Do List Using Outlook 0
C View doesn't refresh (fields or formatting) Using Outlook 1
D Unable to view older emails in desktop app Using Outlook 0
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
