SQL update column
Hendo07
Outlook 2013 32 bit
Hi guys,
Have been trying to update a column in a new table I created with a user defined field column in sql management studio. I have run the below query and getting the error below. Any ideas why this is? Thanks for your help.
update gp
set gp.gp = userfields.userfield32
Msg 4104, Level 16, State 1, Line 2
The multi-part identifier "userfields.userfield32" could not be bound.
daveTQM Sync address book / contacts to SQL / Azure Exchange Server Administration 1
K BCM on SQL Server 2012? BCM (Business Contact Manager) 7
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
P Installation BCM impossible due to untraceable old SQL-server remains BCM (Business Contact Manager) 6
crazyboy SQL 2014 and BCM BCM (Business Contact Manager) 1
O x86 vs. x64 Sql Server 08 Dbase Questions BCM (Business Contact Manager) 2
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
M BCM in Outlook reports maximum database size to 4GB despite SQL Server 2008 R2 BCM (Business Contact Manager) 1
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
O transfer BCM SQL data without backup BCM (Business Contact Manager) 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
M Outlook / BCM / SQL 2005 Express Windows 7 BCM (Business Contact Manager) 3
S BCM install fails at SQL install BCM (Business Contact Manager) 1
M Grab info from attachment and put into SQL db Outlook VBA and Custom Forms 1
J pulling SQL records Outlook VBA and Custom Forms 1
J Moving BCM 2007 Database to a SQL 2005 Server BCM (Business Contact Manager) 2
E Display Outlook Data from more than one Folder like SQL JOIN Outlook VBA and Custom Forms 3
V Business Contact Manager 2007 and SQL Server 2008 BCM (Business Contact Manager) 3
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
N Can I install BCM client without SQL Express? BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
C Cannot seem to use BCM Database Tool on SQL Server 2008 BCM (Business Contact Manager) 4
S will SQL 2003 work for remote server BCM (Business Contact Manager) 1
D 2003 Outlook with BCM SQL server failure BCM (Business Contact Manager) 1
J BCM Database and SQL Server Issues? BCM (Business Contact Manager) 7
D 1 user account not working - SQL Permissions BCM (Business Contact Manager) 1
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
J Microsoft SQL control within custom form Outlook VBA and Custom Forms 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
D Installing SQL Server 2008 Express with BCM installed BCM (Business Contact Manager) 3
K Auto-linking emails by default shared DB BCM 2007 on SQL 2008 BCM (Business Contact Manager) 4
D Install SQL on a remote server for 2003? BCM (Business Contact Manager) 1
V Unable to Install Microsoft SQL Server 2005 express BCM (Business Contact Manager) 2
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
