Grab info from attachment and put into SQL db
  • Thread starter Thread starter manared
manared
I'm very new to VBA, but have been programming with vb.net for several years
now. What I would like to do is grab an attachment (excel), suck out all the
information in that excel file and enter it into a SQL database. I have no
clue how to do that using VBA and Outlook. I'd love to be able to have this
done automatically when the email comes in, but if the user has to click a
button to go through the inbox to grab the specific emails/attachments,
that's alright. I just don't know how to get that attachment info to the
database.
There's no quick and easy answer, but I can guide you down the path.
First, this is a must read:
How to process incoming messages in Microsoft Outlook:
http://www.outlook-code.com/article.aspx?id=62
The next step is to become familiar with the Outlook Object Model:
http://msdn.microsoft.com/en-us/library/bb208225.aspx
Then basically you need to get a handle to the MailItem you want, and grab
the Attachment object you want from MailItem.Attachments collection and call
the Attachments.SaveAsFile method.
See the example here:
http://msdn.microsoft.com/en-us/library/bb219926.aspx
As for exporting the contents of the Excel attachment to SQL - that's not a
question for an Outlook forum! You're looking at ODBC/OLE DB/ADO.NET and the
Excel Object Model for that scenario.
Eric Legault - , MCDBA, MCTS (SharePoint programming, etc.)
> database.
C How do I grab a field property (like .value) so I can modify it via OL code? Outlook VBA and Custom Forms 4
S Using copy paste to grab email addresses from the TO: address fiel Using Outlook 14
V Transfer accounts info Using Outlook 5
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
B Calendar shows too much info by default Using Outlook 0
R Can BCM monitor and select specific emails and use content info to update the client's record? BCM (Business Contact Manager) 1
K Reducing data input, how to auto-fill Account form info into Contact form BCM (Business Contact Manager) 0
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
T doesn't show up previous info (email, contacts and tasks)after windows up date Using Outlook 0
D User Defined Info Gone Using Outlook 1
H Viewing of Calendar info Exchange Server Administration 0
dolke Strange Outlook behavior when receiving emails. More info in the content... Using Outlook 7
B Can I recover info from size limited IMAP file (Outlook 2003) Using Outlook 3
D Extracting Location info from All Day Event in mailboxes into webpage Exchange Server Administration 3
J saving contact info in specific address books Using Outlook 0
M Outlook Macro to get Exchange Info from Mail Outlook VBA and Custom Forms 25
K Outlook admin vs individual access (VBA pulling info) Outlook VBA and Custom Forms 1
D Re: Can contact info be transferred to Word document as in E-mail BCM (Business Contact Manager) 1
A Upgrade to 2007, lost 'Accounts' info BCM (Business Contact Manager) 1
M Check Profile info Outlook VBA and Custom Forms 1
T Trickle down info from updated Accounts to Contacts BCM (Business Contact Manager) 1
R find sender info Outlook VBA and Custom Forms 5
A How to get shared calendar's owner info Outlook VBA and Custom Forms 3
A 2nd meeting confirmation notification ending up in Deleted Items if attachment is added Using Outlook 5
A Strange Attachment Behavior Using Outlook 9
S Paperclip icon shows without attachment in email under Sent folder Using Outlook 0
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
P File Picker for attachment Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
N File Picker for attachment Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
