Macro Not Executing
Alan McGowan
Outlook 2013 64 bit
I am using Items_ItemAdd(byVal Item As Object) to monitor the sent items folder and when a new item is added a userform loads. The userform has several buttons each with their own macro attached. One of the macros selects the item that has been added to the sent items folder and then saves it in MSG format to a user selected folder on a server. If you create a new message and send it all works fine. However if you have say an incoming email open in a separate window and reply or forward this message, the userform loads but the macro won't execute. The problem seems to be due to the email being open in a window. Any suggestions on how to overcome this proble. I have included the macro below that won't run.
' saves email after sending if option to do so is activated
Sub sendandfile()
Dim myNameSpace As Outlook.NameSpace
Dim myFolder As Outlook.Folder
Dim myItem As Outlook.MailItem
Dim myItems As Outlook.Items
Dim lngC As Long
Dim msgItem As Outlook.MailItem
Dim strPath As String
Set myNameSpace = Application.GetNamespace("MAPI")
Set myFolder = myNameSpace.GetDefaultFolder(olFolderSentMail)
Set myItems = myFolder.Items
myItems.Sort "[SentOn]", True
Set myItem = myItems(1)
strPath = UserForm6.TextBox1.Value
On Error GoTo 0
If strPath = "" Then Exit Sub
If Right(strPath, 1) <> "\" Then strPath = strPath & "\"
If TypeName(Application.ActiveWindow) = "Explorer" Then
With myItem
If UserForm4.TextBox3.Value = "NO" Then
.Subject = "[Filed" & " " & Date & "]" & " " & myItem.Subject
.Save
.Subject = myItem.Subject
.Save
' save last sent message
If myItem.Class = olMail Then
On Error GoTo ErrHandler
MsgSaverSAF strPath, myItem
On Error GoTo 0
ErrHandler:
MsgBox "The selected folder does not exist. Please select a valid folder or browse to a folder.", vbExclamation + vbOKOnly
' go back to the line following the error
Unload UserForm6
UserForm6.Show
Private Sub MsgSaverSAF(strPath As String, myItem As Outlook.MailItem)
Dim intC As Integer
Dim intD As Integer
Dim strMsgSubj As String
Dim strMsgTo As String
strMsgSubj = Left(myItem.Subject, 80)
strMsgTo = Left(myItem.To, 25)
' Clean out characters from Subject which are not permitted in a file name
For intC = 1 To Len(strMsgSubj)
If InStr(1, ":&<>""", Mid(strMsgSubj, intC, 1)) > 0 Then
Mid(strMsgSubj, intC, 1) = "-"
Next intC
If InStr(1, "\/|*?", Mid(strMsgSubj, intC, 1)) > 0 Then
Mid(strMsgSubj, intC, 1) = "_"
Next intC
' Clean out characters from Sender Name which are not permitted in a file name
For intD = 1 To Len(strMsgTo)
If InStr(1, ":<&>""", Mid(strMsgTo, intD, 1)) > 0 Then
Mid(strMsgTo, intD, 1) = "-"
Next intD
If InStr(1, "\/|*?", Mid(strMsgTo, intD, 1)) > 0 Then
Mid(strMsgTo, intD, 1) = "_"
Next intD
' add date to file name
strMsgSubj = Format(myItem.senton, "yyyy-mm-dd Hh.Nn.Ss") & " " & "[To " & strMsgTo & "]" & " " & strMsgSubj & ".msg"
myItem.SaveAs strPath & strMsgSubj
If UserForm1.TextBox3.Value = "YES" Then
myItem.Delete
Set myItem = Nothing
Unload UserForm6
It looks like you are grabbing the active open message - use the itemadd macro to assign the newly added message to an object variable then reference that variable.
Do you need this line? Removing this If and working with the copy you assigned to myItem variable earlier should work...
I would probably try to do it this way:
Outside of the macros, declare myItem as outlook.mailitem (and remove the dim that is inside of the macro) then in the itemadd macro, set myItem = item. You won't have to search for the last item added to work with it.
?This sample code changes the subject of the sent message - update the form code and the changesubject macro with your code that saves the message and it should work...
Thisoutlooksession:
Option Explicit
Dim Ns As Outlook.NameSpace
Set Items = Ns.GetDefaultFolder(olFolderSentMail).Items
If TypeOf Item Is Outlook.MailItem Then
Set myItem = Item
ChangeSubject
Code behind the form
Private Sub UserForm_Initialize()
    With ComboBox1
    .AddItem "Subject 1"
    .AddItem "Subject 2"
    .AddItem "Subject 3"
    .AddItem "Subject 4"
    .AddItem "Subject 5"
    .AddItem "no change"
Private Sub CommandButton1_Click()
    lstNo = ComboBox1.ListIndex
    Unload Me
This is in the module:
Public lstNo As Long
Public myItem As Outlook.MailItem
Public Sub ChangeSubject()
  UserForm1.Show
Select Case lstNo
    Case -1
         myItem.Subject = myItem.Subject
    Case 0
         myItem.Subject = "Subject 1"
    Case 1
        myItem.Subject = "Subject 2"
    Case 2
       myItem.Subject = "Subject 3"
    Case 3
       myItem.Subject = "Subject 4"
    Case 4
       myItem.Subject = "Subject 5"
    myItem.Save
Diane, yes that line of code was the problem. Can't believe I didn't spot it. Anyway changing the block of code that started with that line to the following , solved the problem. Thanks very much
myItem.Subject = "[Filed" & " " & Date & "]" & " " & myItem.Subject
myItem.Save
myItem.Save
K Macro Not Executing then send email from Explorer Outlook VBA and Custom Forms 3
