Workflow system
cohello
I have a team of 15 people using outlook to send a document to various parties and upon their approval or changes made in the form the team needs to work further on those documents. Is there any functionality or software through which I can achieve the below results:
1. A workflow can be seen with columns showing which mails have been responded and which are pending to be responded
2. All mails needs to be responded within 5 days so we can see the date and time of mail sent and the response received
3. Mails which have not been responded in 4 days a reminder mail should be sent (not a compulsory requirement)
4. Reports can be pulled out
5. We can put a unique identifier code in the subject line to track the email
6. For emails on which multiple to and fro have happened; it can be seen in the workflow
K outlook workflow: automated task generation Outlook VBA and Custom Forms 4
H Email workflow Using Outlook 1
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
K IMAP Server Wants to alert you to the following: cannpt rename system folder Using Outlook 1
Diane Poremsky RMS Error: System clock has been tampered with Using Outlook 0
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
Diane Poremsky Move Messages from File System into Outlook Folders Using Outlook 0
D Outlook 2010/IMAP - Restoring from system tray changes to unused ibox.... Using Outlook 1
L IMAP and POP email in same Outlook system Using Outlook 1
F System administrator undeliverable in outlook 2007 Using Outlook 1
B Your IMAP server wants to alert you to the following: cannot rename system folders Using Outlook 8
B IMAP server wants to alert you to the following cannot rename system folders Using Outlook 3
S [SOLVED] To make Outlook 2013 the default email system Using Outlook.com accounts in Outlook 3
S Sync Multiple Accounts in Outlook on Single System Using Outlook 5
X Outlook 2010 - search works on one system but not other - identical configurat Using Outlook 2
S system admin error Using Outlook 1
L Outgoing Email attachment error "the system cannot find the file specified" Using Outlook 3
S System Administrator email undeliverable to following recipients Outlook 2007 Using Outlook 4
B Custom Subject based on system time????? Outlook VBA and Custom Forms 2
M hide outlook to system tray Outlook VBA and Custom Forms 1
C Unable to cast object of type 'System.Int32' to type 'System.Byte[ BCM (Business Contact Manager) 1
A how to delete a "user template in file system"??? Using Outlook 7
A User template in file system Outlook VBA and Custom Forms 3
A how to access BCM database after system restore BCM (Business Contact Manager) 6
R How do I reconnect the database files after a system crash? BCM (Business Contact Manager) 11
