Custom Subject based on system time?????
Hi, I have created a shift turnover spreadsheet in Excel and with VBA I am allowing the users to generate an e-mail in Outlook which will send the spreadsheet in the body of the e-mail.
What I am looking to do is have the Subject line in Outlook be based on the system time. For example if the time is 0715 the the subject would be "3rd Shift Turnover" if the system time is 1515 then the subject line would be "First Shift Turnover" and so on.
Using Office 2007 and Word as my editor for Outlook.
And your question is?
If you want the current time use the Now() function to get that. From there
you just need to parse the time using various date/time functions.
"brianharris16" <brianharris16.45efha@invalid> wrote in message
news:brianharris16.45efha@invalid...
> > brianharris16
Thanks for getting back.
In trying to be real basic what I am looking to have is the VBA in Excel generate the E-mail Subject Line based on the time it runs.
If the code runs at 7AM then the Subject would be:
"Third Shift Turnover, 01/26/2010"
If the same code runs at 3PM then the Subject would be:
"First Shift Turnover, 01/26/2010"
Is it possible to have a variable "Subject" based on time instead of a static one in the code (.Subject = "Shift Turnover,") is what I have now.
> brianharris16
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
S Adding Custom Forms Outlook VBA and Custom Forms 4
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
