hide messege issue
DellDurocher
Outlook.com (as MS Exchange)
I am using Outlook 2007. When I delete an email, it is still shown in the inbox but with the line through it. I have looked on line and seen instructions that say select Edit > Purge, but my Outlook does not have purge only delete. I have tried to move to a folder thinking I could delete the folder, but receive an error saying the item is deleted.
Do you have the account set up as IMAP? That is the account type that uses purge. Mark for deletion is typically used with IMAP but can also be used with Exchange accounts if you are working offline.
L Hide Selected Email Address from Address Book Using Outlook 5
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
J Hide/disable "Groups", "Shared Calendars" Using Outlook 2
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
S Hide Timestamp from deleyed message Using Outlook 4
I Outlook 2010 - Remove or Hide Suggested Contact Folders Using Outlook 1
K Hide Default Folders in PST Using Outlook 2
F Hide calendars from shared mailboxes Using Outlook 2
J Ho do I hide the week number on the Calendar Printing Assistant template Using Outlook 4
S Hide Folders in Outlook 2007 (IMAP) Using Outlook 5
C How do I hide distribution list from global contacts for certain users? Exchange Server Administration 1
T Is it possible to hide a mailbox but still send on the behalf of. Exchange Server Administration 1
H Outlook 2007 - hide completed tasks from Outlook Today -Solution Using Outlook 2
N Appointment Body on Custom Page 2- Hide Default Page Outlook VBA and Custom Forms 2
N How to hide pstStore Outlook VBA and Custom Forms 4
H Hide attachment... Outlook VBA and Custom Forms 3
S hide details of appointments in calendar Using Outlook 8
M hide outlook to system tray Outlook VBA and Custom Forms 1
E Can I hide an explorer or make an explorer modal Outlook VBA and Custom Forms 2
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
C Re: Hide BCM toolbar BCM (Business Contact Manager) 1
T How do I hide/unhide folders in outlook inbox? BCM (Business Contact Manager) 1
1 Warning messege Outlook VBA and Custom Forms 3
C Solving the "indexing never finishes" issue Using Outlook 8
Z Hotmail account deleted from outlook and issue with account not exist Using Outlook 0
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
A Clipboard Resize Issue Using Outlook 7
B Outllok 2007 License Expired issue Using Outlook 0
