Outlook 2019 Regex email addresses from body
JunJieW
Outlook 2019 64-bit
New to this forum and been finding solution to make my work easier.
Issue:
I need to forward system auto generated email to users in email body.
eg.
Related email: ABC.ZXC@gmail.com, QWE234@yahoo.com.au
I found @Diane Poremsky post on "find a code in the message body, then forward" and changed Regex pattern to suit my need
With Reg1
.Pattern = "(Related email:\s*([\w-\.]*\@[\w-\.]*)\s*)\.\s*([\w-\.]*\@[\w-\.]*)\s*)"
.IgnoreCase = True
.Global = False
However the result forward recipients is only the first email address. ie. ABC.ZXC@gmail.com. What i need is all email addresses after the word "related to: "
What is the correct pattern to regex those email addresses
Thank you in advance
JJ
Is it all on one line /one sentence, nothing else on the line, with the address separated by colons or semicolons?
If so, this should work - if not try with just \r or \n at the end.
(Related email:\s*(.*)\r\n)
If not, how are they formatted in the line?
Addresses are separated by comma in one sentence.
eg.
My code below:
Sub FWNew(Item As Outlook.MailItem)
Dim Reg1 As Object
Dim M1 As Object
Dim M As Object
Dim strAddress As String
Set Reg1 = CreateObject("VBScript.RegExp")
With Reg1
.IgnoreCase = True
.Global = False
If Reg1.test(Item.Body) Then
Set M1 = Reg1.Execute(Item.Body)
For Each M In M1
strAddress = M.SubMatches(1)
Set myForward = Item.Forward
myForward.Recipients.Add strAddress
myForward.Display
Hi @Diane Poremsky,
I managed to get the email addresses as my forward email recipients but encounter another error.
Run-time error '-2147467259 (80004005)': Outlook does not recognize one or more names.
However the recipients email address become send-able if I leave it awhile which I believe outlook manage to find in address books.
Been googling and check forums but seems like there is no solution to this issue. I have tried the followings
1. Disable check names
2. Custom order of checking address lists in starting with the list with most address.
Any workaround?
Try changing this
to this (the Dim line can go at the top of the macro)
Dim objRecip As Recipient
Set objRecip = myForward.Recipients.Add(strAddress)
objRecip.Type = olTo ' olCC or olBCC
objRecip.resolve
Try changing this
objRecip.resolve
Your resolve solution does not solve the error.
I notice if strAddress is only one email address no issue at all but I will have at least two email addresses.
How about adding a code to "Tab" olTo? This seems to work when I manually "Tab" To field in myForward.Display.
shrydvd Highlight found RegEx pattern Outlook VBA and Custom Forms 3
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
G regex to search for link in attachments? Outlook VBA and Custom Forms 2
D Request help with a macro for forwarding email Outlook VBA and Custom Forms 5
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P anything new on the supposed shutdown of comcast.net email? Using Outlook 6
W frustrating trying to change email password Using Outlook 5
R File not found when sending email with attached pdf file Using Outlook 2
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
P Xfinity/Comcast email service stopping sometime in 2025 - warning Using Outlook 6
O Two identical email accounts in Offline Global Address List Using Outlook 2
H Spam email in Gmail not visible in Outlook Using Outlook 3
L Hide Selected Email Address from Address Book Using Outlook 5
Y QQ on Scheduled Delivery of an Email Using Outlook 0
T Replace Text in Email Subject Outlook VBA and Custom Forms 3
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
M Thunderbird email client - I wonder Using Outlook 1
D Outlook Desktop App Email Software Using Outlook 0
T Outlook 2010 Creating a email 'Group' in OL 2010 Using Outlook 2
T How to set Default FONT for Email composing ? Using Outlook 0
H Finding text in open email Outlook VBA and Custom Forms 12
A Opening a link from an email automatically Outlook VBA and Custom Forms 0
D Outlook 2021 New email reminder Using Outlook.com accounts in Outlook 1
Rupert Dragwater How do I remove an email ending with @gmail.com Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
F Graphics in email / Mac recipient garbled Using Outlook 0
